1978 - 1996 Big Bronco
Power locks and windows
Old Feb 7, 2004 | 03:52 PM
JTs Bronco's Avatar
JTs Bronco
I'm hoping you guys can help me. I have a 1990 Bronco XLT with all power windows and locks. The problem I'm having is with both the locks and windows. The rear window used to only roll down with the dash switch. I replaced the switch and it works now, but it appears to work in reverse. When I press the arrow pointing up the window goes down and the down arrow raises it up. The switch did seem to work the same way before I replaced the switch. For my locks the drivers side switch will lock the door on the passenger side only. The passenger side also locks only the passenger side. But the switch here also seems to operate in reverse. The blue side locks the doors and the red unlocks. I know the actuator is probably bad on the drivers side but what would cause the switches to operate in reverse on both the locks and rear window??
Help guys???
Old Feb 7, 2004 | 03:57 PM
BOJOFASO's Avatar
BOJOFASO
at any time did you connect the battery in reverse polarity? if so you may have polarized the motors in reverse.
Old Feb 7, 2004 | 03:58 PM
Kikwear's Avatar
Kikwear
Reverse operation is a polarity problem.
Old Feb 7, 2004 | 06:22 PM
JTs Bronco's Avatar
JTs Bronco
I haven't hooked the battery up in reverse since I have owned the Bronco. Is there a way to correct the problem or just live with it since they do operate??
Old Feb 7, 2004 | 06:45 PM
BillyBob69's Avatar
BillyBob69
Doubel check your wiring to the switch on the dash. As for the door locks, I had somewhat the same prob and it turned out to be a broken wire in the rubber boot thing that goes from the door to the fender on the drivers side. That door is used more often so wiring can become brittle and break. If you have the haynes or chiltons manual, check it against the wiring diagram. Helps ALOT. I tried all sorts of different wiring on my door locks til I got out the diagrams and started tracing the power. The passenger side is the main circuit for the lock, then feeds the drivers door. Thats how I found my prob. If you dont have the diagrams...just repost and I will post a scanned pic of it here. I have the diagrams from 84 thru 96
Old Feb 7, 2004 | 06:54 PM
JTs Bronco's Avatar
JTs Bronco
Thanks BillyBob69 I'll try that before I replace the actuator.
Pele
Sep 14, 2016 11:43 AM
TexasGuy001
Jun 11, 2016 09:44 AM
Duramaxfanatic1
Mar 20, 2015 06:51 PM
kable
Electrical Systems/Wiring
Aug 23, 2004 09:44 PM
Bleuluv
Bronco II
Dec 23, 2003 07:42 PM
