dove-c heads question
Old Feb 7, 2004 | 10:18 AM
tess100's Avatar
tess100
i got new dove -c heads because old ones could not be repaired anyways the new ones have holes in the bump in the exh port the old ones didnt what are they for? also is this bump the one that is to be removed when porting. i also noticed like a little frost plug in back of heads whats this for old doves didnt have this either. finaly is comp ratio same for all dove-c heads ?
Old Feb 7, 2004 | 10:26 AM
Ford79's Avatar
Ford79
Those holes are part of the emissions system, all of them. The ones in the back (should also be in the front) with the freeze plugs is where the tube that was connected to the smog (air) pump. Yes, that is the bump that is removed (typically) when porting these heads. Don't worry about plugging the small holes in the bumps, they have no real affect on the port flow, even after porting opens them up a little more.
Boz Turner
Jul 27, 2009 10:53 AM
Brom014
Jan 15, 2009 01:13 AM
76 F250 4X4
Nov 29, 2003 07:19 PM
jtlinn
Apr 30, 2003 07:18 AM
85351ho
Jul 17, 2002 02:10 AM
