I have a problem with cold starting on my F-250 7,3 diesel truck. No start on cold engine. I replaced glow system, including glow plugs, relay and automatic. I have a new fuel injection pump and new injectors as well.
When the weather is about 0 degr. Celsius it's starts easier, but now when it's really cold, it won't start at all.
I have a feeling that there is a pressure leakage back to the tank.
Has anyone got good suggestions how to test if that's the case, or can it be something else??
7,3 diesel
Hey check out the 7.3 psd section under superduty/heavyduty trucks above this forum they should be able to stear you in the right direction. You might want to include some info about your truck like Year, mileage motor type. Good luck!
