7.3 idi starts greatcold once hot will not start
I have a 1994 7.3 idi no Turbo
with 33,000 miles. when cold it
will start in less that 7 seconds
but after running the truck and
shutting it off it will not start until
it cools down a good bit. runs
good and idles fine when hot no
check engine. new fuel filter and
glow plugs. idk why it starts great
cold but will not start when hot
u can crank it all day. also the
speed its cranking is normal
speed when hot so its not the
starter
starter
Are you sure the truck only has 33,000 miles on it? What your describing is a worn out injector pump, but I've never heard of one wearing out at that milage. Next time it is hot and won't start, you could pour luke warm water over the injector pump, DO not use cold water, and if iit starts it conferms the pump is bad. WARNING This is extreamly hard on the pump, if the pump is good it can cause it to fail. If the pump needs rebuilt, it is not a long term fix.
95 powerstroke
Ok i have a 1995 powerstroke turbo has 236,xxx miles mods are 3 in down pipe dp tuner 6637 cold air intake mod... I've had the truck for bout two year put roughly 25,000 miles on it starts up cold runs great no missing or no lose in power no hesitation or nothing warms up shut it off won't start back till cools all the way back off then fires up and does great till turned off again then won't start back changed cam sensor un hooked batteries for bout an hour nothing un hooked chip nothing plugged it up and nothing while hot let it cool down fires right up drive anywhere till you shut it off someone help please lol
