7.3 idi starts great cold once hot will not start
I have a 1994 7.3 idi no Turbo with 33,000 miles. when cold it will start in less that 7 seconds but after running the truck and shutting it off it will not start until it cools down a good bit. runs good and idles fine when hot no check engine. new fuel filter and glow plugs. idk why it starts great cold but will not start when hot u can crank it all day. also the speed its cranking is normal speed when hot so its not the starter
You might try posting this issue in this forum further down the page: Pre-Power Stroke Diesel (7.3L IDI & 6.9L) - Ford Truck Enthusiasts Forums
on
hey Jason.check this thread out:
https://www.ford-trucks.com/forums/1...when-cold.html
33k miles on the whole truck? nice survivor you found there!
Do they have a high pressure oil pump like the 6.0s?
We had one at work that would run great all day long, as long as you didn't shut it off, If you did you would have to let it cool down so the oil was thick enough. because the high pressure oil pump was gettting weak , and the computer wouldn't let it start when warm.
Tanner LaGrandeur
02-21-2017 07:38 PM
wdsloot2
04-24-2013 12:02 PM
mildbrandd
General Diesel Discussion
02-23-2012 04:10 AM
