Tough Starting
Old Feb 6, 2004 | 11:22 PM
Mark VIII's Avatar
Mark VIII
Tough Starting
Hello my 78 F250 has been giving me a hard time getting it started. Some days starts right up. Carb seems fine, looks like a weak spark when it does act up. Came out of work tonight cold and rainy out cranking fine wont start before I kill the battery figured I change out the Magic box. Fired right up Question is can I also be having a problem with the pick-up in the Dist. Should I change it also? As always thank you for your help!
Old Feb 7, 2004 | 12:32 AM
LxMan1's Avatar
LxMan1
Usually when they start togo, they will shut you down when driving and it heats up. They don't go bad real often. I'd drive it for a bit and see what happens.
Jimmy
Mr. Crab
Mar 13, 2015 09:56 AM
jolinberg
Bronco II
Apr 23, 2013 04:48 PM
blueline970
Aug 9, 2011 03:28 PM
mcfeeley
Aug 24, 2003 05:47 PM
