OEM seat upholstery kits website?
Does anyone know if someone out there makes seat panel replacements(NOT SEAT COVERS). I don't want to go to a trim shop, I like to do my own work. Basically if I could find matching seat panel upholstery I can handle the hog rings re/re; new foam and such. I just can't sew so I couldn't make panels from scratch. If this post makes any sense or someone here has gone this route before I'd like here from you.
f150 leather replacement
I did this around 5 years ago. I wanted new covers for my '96 XLT but of course no one sells them. I went to the local junkyard and found a filthy nasty '96 XLT seat I paid something like 20 bucks for because it was so bad. I brought it to an upholstery shop & they "de-engineered" it, meaning they took the old panels apart and simply made new ones from the patterns. It wasn't expensive at all...I think around 95 bucks or so. The only place that hog rings are used is on the actual back part of the bench-the piece thats covered with heavy-duty cardboard. All the other parts are secured on by these plastic hook type things that attach to the frame of the seat. This is assuming that you have a bench seat, not buckets.
So I know this doesn't answer your question since you didn't want to go to a shop, but you might be surprised-most of the smaller ones aren't expensive at all. I think that just the seat covers from LMC are more expensive than what I paid! Good luck~
Roger
Roger
I used stockinteriors.com for my new carpet on my 95, and my dad used automotiveinteriors.com for his seat covers. Look for a cover that says it includes the hog rings, thats normally a good sign its a replacement, and not just a slip on cover.
I say do the carpet while You've got the seat out. I put new carpet in mine, as well as sound insulation on the floor (frostking, idea courtesy of extreme makeover, ems truck edition), and took care of any minor surface rust. I'll try and post pics soon, but it transformed the cab, and gets lots of compliments.
Foam seat base
I just bought a '95 Bronco and the driver's side seat needs repair. I'm guessing that the captain's chairs in the Bronco are the same as the ones used in other F series trucks. The twill fabric is worn in spots and the foam is crushed on the left bolster. I found the matching fabric at a local upholstery shop (luck) but I can't find any seat foam that is molded to the proper shape. An upholsterer can make one out of foam blocks with an electric knife, but it is expensive because of the labor involved and doesn't hold up as well long term because the molded ones have a nice, shiny surface from the mold that reduces friction with the fabric. Help!
It'll be heavier foam material than the factory used, but my concern is that it will have a rougher surface than the factory foam, which might contribute to fabric wear as the material won't be able to move around a little when receiving butt contact. Given the number of F series trucks (I believe that the Bronco is basically an F150 from the doors forward) that Ford has put into service in the last 30 years one would think that there would be a market for repop set foam.
on
I found some NOS upholstery for my truck on Ebay a while back.
on
Is there ANY supplier (Off the shelf) of factory style upholstery for 92-96 OBS, particularly Super-cab Captain's chairs?
Truck Parts and Truck Accessories
Haven't looked at LMC in ages, thanks.
Nice to have an all else fails fall back.
Have tossed around idea of grabbing a spare at the JY, stripping the upholsetry & pulling the stitching for pattern.
Shopping the job of sewing up replacement to a local upholsterer.
My wife hates the velour.
