Thermostat malfunction?
Old Feb 5, 2004 | 05:34 PM
patrick_q's Avatar
patrick_q
I have a '99 Ford Ranger with a 2.5L 4cyl engine. The problem I've been experiencing is that the engine is barely warming up and the heater isn't working that good because of it. I called my local autoparts store and they said they couldn't find a thermostat for it in the catalog. I popped the hood while I was there and myself and the guy at the store looked and it doesn't look like the engine has a thermostat. the only thing we could figure was that it had an electronic valve of some sort.
What is the best thing I can do to troubleshoot and fix the problem??
thanks
Old Feb 5, 2004 | 07:59 PM
Thoth88's Avatar
Thoth88
I had the same problem when I bought mine, somebody replaced the thermostat and put it in backwards. On my 94 2.3l the thermostat is 'under' the top radiator hose. If you follow the hose from the radiator to the block your thermostat should be under the metal housing the hose ataches to. quick check would be to remove the top radiator hose at the block and using a flash light see if the thermostat is open and go from there.
Old Feb 5, 2004 | 08:19 PM
Ken00's Avatar
Ken00
I agree, bad thermostat.
Old Feb 17, 2004 | 05:44 PM
patrick_q's Avatar
patrick_q
Ok, I finally got the right thermostat and put it in today. Truck warms up like it is supposed to and runs fine...BUT now the heater blows cold air. Before the thermostat change it would at least blow warm air.
Does anyone have any idea what would cause this?
Old Feb 17, 2004 | 08:15 PM
Lone_Ranger01's Avatar
Lone_Ranger01
Bad heater core possibly, what temp. thermostat did you put in?
Old Feb 17, 2004 | 08:49 PM
Ken00's Avatar
Ken00
Do the heater hoses at the firewall get hot?
Old Feb 18, 2004 | 12:12 AM
patrick_q's Avatar
patrick_q
I'm not sure if the heater hoses get hot or not. I'll have to check that in the morning.
As far as the thermostat, I'm not sure. It's a Motorcraft part that I got from the dealership.
Old Feb 18, 2004 | 05:41 AM
Bob Ayers's Avatar
Bob Ayers
Sounds like you didn't get all the air out of the system when you refilled it...
Old Feb 18, 2004 | 07:17 AM
patrick_q's Avatar
patrick_q
Got it working this morning. I had to add more coolant to the system and probably while doing this was able to get all of the air out of the system.
