>On a stock F-250 Superduty Crew cab shortbed. What are the
>largest wheel and tire combinations that can be used
If it is a 4x4 you could run 10" wide wheels and 33" x 12.50 tires no problem.
35" x 12.50s fit but will rub on your inner fenders at lock, could do some damage if you wheel it.
I have a pic in my gallery with 35" on my stock 250, but I also had the X springs , so mine sat more level than most.
