Stock wheels, radial tires?
Old 10-19-2002, 09:39 PM
Karm's Avatar
Karm
Karm is offline
Karm is starting off with a positive reputation.
I love the look my '52 F-1 has with the stock wheels, but the front bias plys and rear cleats give it a pretty rough ride sometimes. I want to switch to radials but need a little advice, I don't want to get a new set of wheels as it will take the stock appearance away.
What have you guys done to continue using the stock wheels? What size/brand of radials have you put on?
Thanks
-Kevin
Old 10-19-2002, 11:43 PM
mtflat
mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
I run 215-85-16LT's blackwall out. Looks similar in profile to stock tire and drives much better.
Old 10-21-2002, 10:17 AM
DonF
DonF is offline
DonF is starting off with a positive reputation.
On my 49 F1 I'm running 235-75-15. Relatively cheap, easy to find, ride great and also the same size as my newer truck (1967). There was not a single original 16" rim on my truck when I got it so going 15" was not that hard a decision. It had one stock(not 49) 15" smoothie so that's where I started. Now I have two 15" x 5" and two 15" x 5 " rims. Eventually, maybe they will all be the same size.
Old 10-21-2002, 01:42 PM
Kai's Avatar
Kai
Kai is offline
Kai is starting off with a positive reputation.
This forum made me go away from my plan to run tube type 7.00x15s on 5x15 wheels (especially with the no speed limit on our Autobahn). I now have 205/75-15s on 5.5x15" in front and 235/75-15s on 6x15" in rear on my 54. All on black stock wheels. No hub caps. No trim rings. I also mounted the white lettering facing inside for the stock look. By the way, one reason for having the big'n'little combo is that I needed the extra load rating. The 235/75-15s is the widest tire you can mount on 6" wide wheels (as per the datasheet of the tire manufacturers).
Greetings from Germany !
Old 11-06-2002, 03:22 PM
Midnite Cruiser's Avatar
Midnite Cruiser
Midnite Cruiser is offline
Midnite Cruiser is starting off with a positive reputation.
I have been running 225/75 R16 Monarch Trailmaster tires on my '55 on stock 16" rims. We matched the diameter to an inflated but scary looking original bias ply. Speedo reads accurately, and it really calmed down the revs on the 312 that had been stuck with F70/15s and the stock 3.92 rear.
The trailmaster tread is an M&S but not wildly knobby, rides pretty quiet, and adds just enough meat of width to modernize the look a notch. (those stocker bias plys really made a 'shopping cart' out of the Bignose)
:P
Midnite Cruiser
Old 11-07-2002, 09:12 AM
DS02F250
DS02F250 is offline
DS02F250 is starting off with a positive reputation.
255/75X15 BFG Radial T/A's on after-market half-moons on my '59. Ride is fine (I'd just like to reduce the amount of play in the steering wheel)!
DS
Old 01-30-2009, 02:15 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
Lets run this around again
Old 01-30-2009, 02:27 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
There appears to be only one 7x15 tire still on the market, everything is moved towards 16" since this thread was started. Yokohama makes it and not many places sell it. I ain't springing for any of the Coker vintage-style tires.
Old 01-30-2009, 04:43 PM
bobj49f2's Avatar
bobj49f2
bobj49f2 is offline
bobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant future
I bought a set of Mexican 16" bias ply tires, mounted on stock rims, from restoringmy46 last year. My panel came with some cheap 15" radials on steel mag rims. I could notice the difference when I changed them, it improved the ride considerably. I was surprised, from what I've read I thought radials were suppose to be a lot better than bias ply. Maybe, I just had a bad set of radials.
Old 01-30-2009, 05:51 PM
HT32BSX115's Avatar
HT32BSX115
HT32BSX115 is offline
HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.
This is a REALLY old thread!!!
I wouldn't drive any of these trucks without radial tires so I have 9.00-20 radials on the F-600!!
Old 01-30-2009, 06:17 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is offline
truckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant future
I'd be interested to hear whether you guys have experienced any rim cracking after putting radials on stock drop center rims. I was looking through the Coker catalog today for the other thread on this subject and right there is a disclaimer about the risks of doing this combo. Have any of you had trouble doing it? Stu
Old 01-31-2009, 10:40 AM
HD74's Avatar
HD74
HD74 is offline
HD74 is gaining momentum as a positive member of FTE.
I'm running Pirelli on mine and I like the way they handle the road. I'll get you the tech on the tyre's later.
Old 01-31-2009, 02:35 PM
HD74's Avatar
HD74
HD74 is offline
Here's the spec's on the pirelli's LT235/75R 15 Norseman. I thought I had 16, must of been thinking about my bike.
Old 01-31-2009, 05:34 PM
havi's Avatar
havi
havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
I've known that the mass makers are moving towards 16" tires. However I believe most still make 15", though really nothing narrower than what's provided for a 6" rim....which would be for 235/75/R15's. Looking at my '62 M.Y. cars, finding a 15" wheel will be spendy at best, I think. Finding tires to match will be even spendier compared to 5 years ago. (15" needed to clear disc brakes) Even with the 16" wheels on my trucks, I can't imagine we'll be able to just go to the nearest store to buy a set of tires.
bradphx
63
09-24-2018 11:19 AM
03-09-2016 12:40 PM
Aerostar
01-14-2015 03:16 AM
miko6810
Modular V10 (6.8l)
06-04-2014 06:14 AM
walterdanek
16
02-16-2001 07:56 PM
Quick Reply: Stock wheels, radial tires?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
