Bronco II Ford Bronco II
truck wont start
Old Feb 4, 2004 | 08:41 PM
lakahahahman's Avatar
lakahahahman
truck wont start
i went to auto parts store today and shut truck off to go in
1987 BII eddie Bauer
was fine when i came out to start it it started fine but starter stayed engaged
so i got out and bumped the solonoid and it stopped
but when i went to restart the truck it cranks but no firing
i took coil wire off coild and got it turned over and got zapped but doesnt seem to be firing to plugs ??
any ideas
Old Feb 5, 2004 | 08:05 AM
WeWonIt's Avatar
WeWonIt
Distributor, maybe. Mine did kinda the same thing, and after I replaced the starter, all the terminals for the coil, the distributor cap, all the plug wires and plugs. I finally figgured out that I was not getting fuel, due to the external fuel pump's wire connections. That may sound stupid but mine showed almost the exact same signs, and your getting zapped story sounds the same too. Take an extra plug, ground it and plug your #1 plug wire in to it and have some one turn the truck over, with your garage lights off you should see spark. If not its an ignition problem, or a computer problem. If you have spark, make sure you have fuel. Mine has an attachment on the intake drivers side that resembles a valve stem, just remove the cap and push the inner valve to relive fuel pressure, if fuel squirts out then you have good fuel pressure, if not that may be your problem. Good luck with it
Old Feb 5, 2004 | 12:54 PM
lakahahahman
i checked the fuel schrader valve and there is definately fuel squirting there and i can hear my fuel pump prime
Old Feb 5, 2004 | 03:27 PM
WeWonIt's Avatar
WeWonIt
It was just a thought, how about the spark at the plug? Good luck with it.
Old Feb 6, 2004 | 12:06 PM
lakahahahman
as stated in the first message i could not get any spark at the plugs and i dont know why
cap is good
wires are good
rotor is good
plugs are good
Old Feb 6, 2004 | 02:02 PM
Ken00's Avatar
Ken00
If I understand correctly you have spark from the coil to the distributor but no spark out of the distributor. Is the distributor turning when you crank it??
Old Feb 6, 2004 | 10:43 PM
lakahahahman
HMMMM good question i will check that in the morning
worst case scenario if it isnt what would it be
Old Feb 7, 2004 | 06:02 PM
Ken00's Avatar
Ken00
I would suspect the drive gear on the end of the shaft. Make sure you make the position if you pull it out.
Old Feb 8, 2004 | 02:21 PM
lakahahahman
ok i checked and the rotor is turning when i crank the engine
Old Feb 8, 2004 | 04:30 PM
lgamech's Avatar
lgamech
Ok heres an easy thing to check. happened to me a few times. Check the RED lead from the starter relay on the inside fender wall. Its a small lead connected to the relay just above the two battery connections. If the line is loose or damaged in any way you will get the engine to crank , fuel and spark but it will not start.
I don't know why but it does fix the problem sometimes.
Old Feb 8, 2004 | 06:45 PM
Ken00's Avatar
Ken00
Since you have spark to the top of the distributor cap (center) but none leaving it has to be either the cap, rotor or a bad contact between them.
Old Feb 10, 2004 | 11:40 PM
lakahahahman
wooooo hoooo changed ignition module on distributer and it fired right up
thanks everyone
sns2832
Feb 23, 2014 11:04 AM
yzman
Dec 11, 2013 07:55 PM
96eddie5.8
1978 - 1996 Big Bronco
Jan 6, 2006 10:48 AM
lurch
Mar 22, 2003 07:44 PM
Roadrhino
Dec 26, 2001 02:09 AM
