rear end sagging...
Old Feb 2, 2004 | 11:13 PM
makeoutmusic's Avatar
makeoutmusic
rear end sagging...
My rear end sags when my 93' E150 conversion V8 302 is fully loaded (about 350lbs addition weight directly above axle and 2000lbs 6x10 trailor hitched up) I am considering either an "add a leaf" which would be a cheap solution, or new heavy duty leaves. i am wondering two things... Are the "add a leaves" worth it in the long term? and if not, would the heaviest duty E150 leaf be enough? could a E250, or E350 leaf fit?
Thanks, Tyler
Old Feb 3, 2004 | 09:58 AM
blue_mule's Avatar
blue_mule
E250 or E350 springs will not fit, they are shorter and wider than E150.
the add-a-leaf direction IS the cheapest way to go. Or,
AIR SHOCKS.
Go to
www.partsamerica.com or
www.autozone.com
maybe even www.jcwhitney.com
Old Feb 3, 2004 | 12:53 PM
makeoutmusic
Much thanks, Tyler
Old Feb 5, 2004 | 02:17 PM
Mustang 5.0's Avatar
Mustang 5.0
Also, check the tounge weight of your trailer. I tow a Mustang on mine and my tounge weight is never more than I can lift comfortably. about 100-150 pounds. Using an anti-sway bar on the trailer and I"m comfortable with it, and get a well balanced rig.
I would also still suggest a add-a-leaf on the springs.
Old Feb 8, 2004 | 11:21 AM
sprice16v's Avatar
sprice16v
Go to a local spring and or frame shop to have a new rear leaf added to the set, I have found doing this instead of buying one from a mag., works much better ,and the overall cost is about the same.
annaleigh
Jul 26, 2015 08:04 PM
Sous
20
May 11, 2015 07:37 AM
minnesotafisherman
47
Oct 4, 2012 01:52 PM
nutmg1
Aug 15, 2011 09:47 PM
muddyford75
Dec 30, 2003 06:11 PM
