Directional Controls
Old Feb 2, 2004 | 09:59 PM
nhfire 77's Avatar
nhfire 77
Angry Directional Controls
When i try to turn the directional arm for a right turn it only works if I play around with it. It works best if i apply sligth preesure on it towards the front of the vehicle. Also when you turn on the 4-way flashers only the left side works. Occasionally when it does work, you can hear a scraping electrical sound.
HELP
I ve checked fuses just incase,
I cant find the relay
I hope this isnt the switch in the steering column,
ANY ideas???
Old Feb 2, 2004 | 10:00 PM
96explorereddieb's Avatar
96explorereddieb
Sounds like the multifunction switch...the switch you're talking about. It's like $40 at the dealer. It's not that expensive.
Old Feb 2, 2004 | 10:13 PM
nhfire 77's Avatar
nhfire 77
thats a good sign, its something a basic mechanic could do, no special skills/ knowlegde, other than how to put it back together??
Old Feb 2, 2004 | 10:23 PM
96explorereddieb
It's easy. It'll take you about a half an hour to R&R. If you need directions, let me know.
Old Feb 2, 2004 | 10:29 PM
nhfire 77's Avatar
nhfire 77
that would be huge help if you have the directions available any thing to go with!!!!
Old Feb 3, 2004 | 07:49 AM
96explorereddieb
Here you go!! Straight from Ford's shop manual:
Removal
WARNING:
THE ELECTRICAL CIRCUIT FOR AIR BAG DEPLOYMENT IS POWERED DIRECTLY FROM THE BATTERY (10655) AND BACKUP POWER SUPPLY. TO AVOID ACCIDENTAL DEPLOYMENT AND POSSIBLE PERSONAL INJURY, THE BATTERY POSITIVE CABLE MUST BE DISCONNECTED FOR A MINIMUM OF ONE MINUTE TO DE-ENERGIZE THE BACKUP POWER SUPPLY.
1. Disconnect battery to starter relay cable (14300) and wait at least one minute for air bag backup power supply to discharge before beginning work. Refer to «Section 01-20C».
2. Remove upper and lower steering column shrouds (3530) as outlined in this section.
3. Remove two self-tapping screws retaining multi-function switch (13K359) to steering column tube casting. Disengage multi-function switch from casting.
4. Disconnect the three electrical connectors.
Installation
1. Install three electrical connectors to full engagement.
2. Align turn signal and windshield wiper switch mounting holes with corresponding holes in steering column tube casting. Install two self-tapping screws, making sure to start screws in the previously tapped holes. Tighten to 2-3 N-m (18-25 lb-in).
3. Install upper steering column shroud and lower steering column shroud with screws. Tighten to 0.7-1.11 N-m (7-9 lb-in).
4. Note: When the battery has been disconnected and reconnected, some abnormal drive symptoms may occur while the powertrain control module (PCM) (12A650) relearns it adaptive strategy. The vehicle may need to be driven 16 km (10 miles) or more to relearn the strategy.
Connect battery to starter relay cable.
5. Check tilt lock lever and multi-function switch for proper operation.
illgorhythm
Jun 14, 2010 06:48 PM
tombidle
Feb 14, 2004 09:18 AM
Swampdonkey09
Jan 9, 2004 06:03 PM
Super D
Apr 6, 2003 11:00 PM
1999XLT
Sep 15, 2002 07:21 PM
