Turn Signal Not Flashing
Old Feb 3, 2004 | 09:03 AM
bbuffalo's Avatar
bbuffalo
Question Turn Signal Not Flashing
A friend of mine has a exployer that the rt. turn signal and brake light is not working. She said it come on at the dash but does not flash. I am assuming it is the bulb. How do you access this on the exployer. Do you get to the bulb from the inside or the outside? Thanks
Old Feb 3, 2004 | 09:10 AM
satcomjimmy's Avatar
satcomjimmy
Front bulbs accessed from under hood, rear are accessed via open gate.
Old Feb 3, 2004 | 09:35 AM
99Xplr's Avatar
99Xplr
You will need to take the right light housing off the truck to get to the bulbs. Once you remove the screws and pull the housing, it is pretty straight forward what to do.
