np435 to c6 swap
np435 to c6 swap
I have a rusted out cab that will be swapped with a another cab that was an automatic. the steering column is already set up for auto. What other things will i need to complete the swap? Thanks
Make sure you get the correct C6 trans to bolt up to your engine. Small blocks and big blocks use different bell housing bolt patterns.
You need: transmission shift linkage, iether an auto trans radiator with tranny cooler in the tank or an aftermarket seperate tranny cooler and the lines to go to it, the trans dipstick and dipstick tube for your vehicle, the correct trans tailshaft and housing for your vehicle (2wd or 4wd), rear trans mount and maybe crossmember, possibly a different length driveshaft. There's probably a few things I missed but that will get you most of it.
I have a few trucks that are just part trucks now from 1969-1990.
F100,F250,F350.
I'm welding up a 71 cab now that I no longer want thats on a F-350 chasis. If you need stuff I need to clear up space. What year truck you trying to restore? I have a lot of FE stuff...
F100,F250,F350.
I have a 69 and 71 cab. I have a lot of "stuff" for that era truck that I have accumulated some how or another. What motor are you looking to attach the C6 to?
Send an instant message when you get a chance.
