i dont know why but i keep messing up my amps.....i had a blauntpunkt an it was working fine for about 2 months then it stoped playing...sooooooo i bought another amp....this amp worked for about a month........it sounds like the subs are blown but i tryed other speakers an they do the same.......i THINK that i might have the ohms mixed up....could that have anything to do with it?>>>if so what would be the best way to wire my subs?>.....thanks
First I would check your wiring and make sure you don't have a short somewhere? Did any fuse blow when the amps give up? Next, you need to find out what ohms the subs are (single VC or dual VC makes a big difference too) and check out these wiring diagrams to see what the load on the amp really is. Hope that helps.
yea it does but it dosnt come on.......and also i found today that one channel make a hard thumping noise and the other side sounds like the speaker is blown.........
