Hard to Start
Old Feb 2, 2004 | 05:33 PM
Dilligas's Avatar
Dilligas
I need help.......again.
Truck won't start. I went on vacation so it's been sitting for a couple of weeks. I got back and went to start it and it took about an hour. It sat again all weekend and now it won't start again. It'll turn over, but it won't fire. It's got gas, the batteries good, I pulled the plugs and cleaned them off because it's been running rich, (that's another question for later.) and they got fouled. Still won't start. I'm letting it sit for an hour or so incase she got a little flooded while I was trying to start.
Anyway, anyone else have this problem? It always seems hard to start if it sits longer than a weekend, but this is the worst.
Old Feb 2, 2004 | 06:12 PM
mypa'struck's Avatar
mypa'struck
Just a guess, but I would check the points, maybe give it a good tune-up. My truck is a bear to start when it's flooded. Maybe check the floats in the carb to see if they are letting in too much gas. Or even rebuild the carb if it's been awhile.
Dennis
Old Feb 2, 2004 | 08:23 PM
Fritolay's Avatar
Fritolay
check the accelerator pump and the floats on the carb
Old Feb 2, 2004 | 09:14 PM
Bagged70F100's Avatar
Bagged70F100
You say your truck has gas. Does that mean you actually can see the gas flowing into the carb or the truck's tank shows that there is fuel in it. My suggestion is to pump the living daylights out of it, turn it over a couple times, and pump the heck out of it again. Sounds like your fuel pump is going bad and leaking off. Letting gas seep out of the fuel line back into the pump instead of staying in the line and to the carb. THe accellerator pump in the carb might also be leaking and letting gas seep out. The 360 in my '72 had the accellerator pump problem, and the 302 in my '70 had the fuel pump problem, so that's how I know that you may be having this problem,but, I've been wrong many times before! You can actually take a good accellerator pump out of an old carb and put it in your carb if you be really careful not to tear it and you know the old one didn't leak either. I did this with my beater '72. Maybe this will help dude.
Old Feb 2, 2004 | 10:30 PM
Dilligas's Avatar
Dilligas
It's a brand new Carb so I don't think it's the Accelerator pump. Fuel pump is a possibility. I have a clear fuel filter and it doesn't look like any fuel is leaking back down. I haven't actually looked though. Thanks for the help.
Old Feb 5, 2004 | 02:01 PM
Dilligas's Avatar
Dilligas
Apperently if the coil connections are dirty or loose it can cause this. Lol. My neighbor reminded me that a wire from the coil seemed loose last time we were messing with it. So, I went down and checked the wires, they seemed ok. I pulled the connections off the top of the coil and the posts looked a little dirty, I wiped em off and made sure it was on tight, then I went to try to start the truck. Fired up on the first try.
Live and learn I guess.
Thanks for the help guys.
Dan
Old Feb 5, 2004 | 05:24 PM
joker830's Avatar
joker830
had a problem with starter trys starting but killed battery was turning over fine start was bad but did not sound like it
River19
19
Feb 22, 2017 04:51 PM
Cperk
Jan 2, 2017 12:21 PM
Candie711
Modular V8 (4.6L, 5.4L)
Dec 27, 2016 07:16 PM
dankan
Escape & Escape Hybrid
Dec 13, 2015 07:11 AM
Flat Four
Oct 4, 2011 08:07 PM
