Voltage regulator wire ?
Old Feb 1, 2004 | 08:43 PM
peter81083's Avatar
peter81083
Angry Voltage regulator wire ?
well i finally got my headers and dual pipes run on my 79 ford f-100, which took WAAAYYY more work that expected....but i love it now that its done ......but now, as if it appeared out of nowheres, ive got a yellow(with black stripe) wire just sticking out of the plug on my voltage regulator. its got a stripped end, and looks as if it was tied into something , but neither I or 2 friends could find it anywheres. since this wires been disconected, my alternator light on my dashhas been lit. does anyone know what this wire is....and where i should start looking for the other end? i know this is kinda vague....but i figured id ask before i went crazy searching for it (like my last electrical problem). thanks for any help
Old Feb 1, 2004 | 08:48 PM
Mil1ion's Avatar
Mil1ion
There is a wire for a capacitor/choke/condensor that comes out of one of the connections
Old Feb 1, 2004 | 08:49 PM
peter81083's Avatar
peter81083
that is sometimes without the condensor on it.
where can i find more diagrams like that?!?!
Old Feb 1, 2004 | 08:58 PM
Torque1st's Avatar
Torque1st
Posting Legend
You can get diagrams in the OEM service manuals on CD from the online store.
Old Feb 1, 2004 | 10:48 PM
78fordman's Avatar
78fordman
I Have a couple of diagrams, but i have no clue on how to post them. I think you would have the 4-wire setup, because to my understanding the 3 wire was for the gauge setup, and the idiot light has the 4-wire. If you want i can e-mail you the diagram.
Old Feb 1, 2004 | 10:56 PM
Mil1ion's Avatar
Mil1ion
I removed the diagram after he viewed it.
Old Feb 2, 2004 | 06:18 AM
peter81083's Avatar
peter81083
i saved the first diagram the second i saw it, lol.....but yeah, id love to get more. my email is peter81083@hotmail.com.
....what is the "idiot light"?....is that what this wire goes to?
its almost daylight over here, and im going look for a possible connection as soon as the sun gets up. thanks for the help!
Old Feb 2, 2004 | 11:14 AM
grapegravy's Avatar
grapegravy
Is the condenser still there with the voltage regulator? A small silver cylinder that attaches with the voltage regulator, almost looks like a part of it but is in fact separate.
Old Feb 2, 2004 | 09:57 PM
peter81083's Avatar
peter81083
got it
turns out, the wire slipped out of a connection with the alternator wire, and the in-line fuse holder ive got connectiong my alternator to my solenoid. finally got that fixed, and re routed my starter wire...so the headers are all good now .....id still like to do something about my emissions though....it still smells like its burning really rich. i want to put in a better coil, plugs, and wires....but only if it would give me a little extra power (i figured this would go good with a rich gas mixture).......whats everyone elses thoughts?
Old Feb 3, 2004 | 07:32 AM
78fordman's Avatar
78fordman
Msd box, with the double spark, that would give you a lot more power, it will burn all of the gas, thats for sure.
Old Feb 3, 2004 | 09:35 PM
LxMan1's Avatar
LxMan1
Check the carb if it is running too rich.
Old Nov 16, 2005 | 04:03 PM
fordnjneer's Avatar
fordnjneer
Wire with fusible link?
There is a fourth wire coming off my regulator that seems to have a fusible link on it. The end away from the regulator is broken off (likely from my hasty removal of everything in the engine compartment to install my 351W) Since I cannot see any wires going from the regulator to the solenoid or battery, I am assuming that this is what charges the battery and the reason my truck runs but needs repeated jumping. To replace this, can i just connect it to the positive terminal of the solenoid? Instead of a fusable link, can i use a large fuse? What amperage rating would be appropriate for this position in the charging system? Thanks for all the great info on this site. My 351W 78 F-150 has been a total success because of it!
Old Nov 16, 2005 | 06:59 PM
73FOMO's Avatar
73FOMO
don't think there is a wire with a fusible link. The condensor kinda looks like one, but it is not.
Old Nov 16, 2005 | 08:52 PM
fordnjneer's Avatar
fordnjneer
What do I connect that to? The positive terminal on the solenoid? Maybe that is the problem. Can't do it now because it's raining in NJ.
