Full time 4WD T-case options
My truck is coming out of hibernation thanks to a new job with a lot more pay and a turbo'd 460 is in the works. I want to run all wheel drive on the street and strip for traction on the launch.
Actually the 203 is almost as strong as a 205. It is chain driven, but if it has a new chain in it, it would last at least 100K miles, but with the power you'd be putting through it it still should last at least 50k. The C6 is a very durable transmition and with a shift kit it should hold up pretty good. To strengthen the rest of the drivetrain, get bigger and stronger u joints and yokes.
Just wondering, how much power do you what out of your 460??? I mean you could mod it for a pretty easy 700, + turbo who knows!
I've already had the 205 gears bind up crossing a paved road while off roading, and it took a decent size hit head on from another truck to unbind it. I was amazed the hubs didn't snap first. That's what has me hunting down a Ford 203 on ebay, which is damn hard to find. The drudge/chebby one are all over the place. Once I get that, then the chain to hold up is the next part.
I'm going to keep the 400 in it till the all wheel drive is sorted out, then the fuel injected 460 (possibly stroked to 545 if the Scat kits stay cheap enough on ebay) running the Megasquirt system gets built. Once that is broken in, the vacuum will become boost.
The 9" already has 35 spline axles stock, I counted when I changed the diff after the spider gears welded themselves to thier shafts, and I'm not going to be spinning huge tires, I'm thinking 31" X 13.5" in the back and 31" X 12.5" or 11" in the front. If i spin the wheels a little, that's okay. I'd rather that than 100% traction followed by snaps and pops of the driveline.
The 44 in front may get a limited slip but I'm thinking yolks and drive shafts are going to be the main leak wink.
Its going to be a learning experience, I haven't seen a 6000lb all wheel drive drag truck yet, so once it gets going, I'll share my successes and carnage with everyone here.
Have you already mapped out the piping on the truck for the turbos? You going to run twins or just a big single. and what about the manifolds? Is it possible to use factory pieces and bring the hot pipe back down and to the front and mount the turbo low or is a custom built exhaust manifold needed?
Sorry for all the ? just thought since you are working on your project might pick your brian so save me from using mine, since mine might melt down at any moment if I overwork it.
I need to start looking into shortie headers that can possibly be turned backwards so that the collectors point to the front of the truck or upwards. That would make the the plumbing a lot more easier. A single turbo from an older power stroke may be the right size. Also, the inner fenders are most likely going to be taken out to free up room. The only thing I have in there now is an MSD that can go on the firewall and the battery.
The turbo is for later. For now, I need to get the drive line and 460 EFI squared away. The Megasquirt is a basic EFI controller that you put together and solder jumper wires on the board to set the # of cylinders, injectors, coils and other variables. The base kit is below $300, and can have an added boost sensor piggie backed to handle forced induction. The website www.boostang.com was my first time seeing this system, and the guy who owns that car is most likely going to get bombarded by questions from me when I am assembling the system. He has a page on that site dedicated to the Megasquirt system.
I know I could get a factory EFI system for a 460, but this thing is MUCH more wide open for HP potential. If the 460 becomes a 545, it may not need the turbo, but who knows. It may get done just for the cool factor.
As for the cost of an NP203, I have no idea. Let me look around and see what the local bone yard wants for one in similar condition without a core and I'll come up with an offer.
Okay, I'm off to bed, I have to go get dunked in a pool while inside a fake helicopter shell and escape as quick as possible tomorrow as part of being certified to go work offshore.
.......i would just transfer weight to the back and try to get more rubber on the ground with tire selection
The closed chamber aussie heads in the gallery also may be back up for sale once I get the 460. They've been in my shed with regular coats of oil to keep the surface rust away. They have already been semi ported, just the rough casting flakes have been ground away.
Don't get me wrong, you have a great project going on. My 4x4 toyota pickup with a 70 vette 350 doesn't go a lot of places without the trailer. In fact I'd rather ride a horse on the street. It's really that bad with lockers front and rear, a monster cam, and 35 inch tires. It spends lots of time on a car trailer on the way to mud rallies, and hill climbs. However, it is wonderful off road, for which it is now designed to do very well. A couple of years back with strip tires, just for giggles and fun, it ran a 12.63 in Palmer, Alaska, in the quarter mile at 7,800 rpm's. It did win best in the foreign class, and that was over all the little rice rockets. They were very envious. It was very scary, and I don't know how fast I was going because about half way down the track the spedo was maxed out at 85 mph.
