Difference in metering rods?
Old Feb 1, 2004 | 07:41 PM
hbronco's Avatar
hbronco
I just went out and grabbed some rods for my carby as it was running way to rich.
Im stumped tho, as there seems to be no real physical difference between them, are the differences so minute we cant tell the difference, it was like i was putting in the exact same size rods
I replaced the stock rods in the 1405 edelbrock, with #1457 073X052, and also have #1459 075X047 but like i said, i cant tell the difference between them, any one shed some light?
Thanks
Old Feb 1, 2004 | 10:28 PM
bob arrington's Avatar
bob arrington
did your carb work better? if it did ,thats the difference,i know that seems simplistic , bob
Old Feb 1, 2004 | 10:36 PM
hbronco's Avatar
hbronco
Honestly, could not tell the difference, will take it to emissions and see what happens, if it fails, then im thinking i will need to jet it down abit to the #1427 .98, which is 8% lean.
Old Feb 2, 2004 | 12:21 AM
LxMan1's Avatar
LxMan1
The first number on the rod controls the low speed/part throttle mixture. The second/smaller number is for wide open throttle, or when the vacuum drops below the spring pressure that pushes them up. I think that 5" is stock.
So the 075x047 will be leaner on the low end and richer on the topend than the 073x052.
The numbers are the thickness like .073".
Jimmy
Old Feb 2, 2004 | 01:07 PM
hbronco's Avatar
hbronco
Thanks LxMan1, that clears up alot, i think i will need to put in the leaner ones for the low end, as emission test does not go above 2500 rpms.
Old Feb 3, 2004 | 02:35 PM
67 F250's Avatar
67 F250
The numbers are the diameter of the thick and thin parts of the rod in thousandths of an inch. Thus 073x052 = .073" x .053" . Hard to see the difference between .073" and .075"!
Old Feb 3, 2004 | 02:43 PM
hbronco's Avatar
hbronco
Heh, yeah, no wonder I could not see any difference
Old Feb 3, 2004 | 10:27 PM
LxMan1's Avatar
LxMan1
It is just like puting a 2 size smaller jet in it without getting gas on you and everything else! So much beter than a Holley.
Old Feb 5, 2004 | 04:19 PM
hbronco's Avatar
hbronco
Just an update, truck passed emissions The 8% lean metering rod I put in did the trick.
Thanks for your input.
