4.2L v6 conversion to 5.4L v8
I am trying to convert a 4.2L v6 engine into a Lightning 5.4L V8. The problem is I do not know everything that is required to be converted. I know that my old transmission must be replaced along with the computer. That's all i know. I need some advice in what more i can look forward to changing to make it work.
ac
ac
In addition to the engine, you will need to change the transmission, driveline, radiator cowling, computer, full ECM wiring harness, etc. after you get it running you will probably find the stock springs, shocks and stuff are too soft for the added weight so you will need to upgrade them also. IMO this would not be a project for the weak of heart.
or just go buy a used one with high miles I dont think that is a project work taking up, at all. I dont make a ton of money, but theres no way I would sink that kind of money into a truck. Byt the time you count up the time money and broken knucles, I bet you could have easily bought a slightly new L.
Good luck
Garrett
Good luck
Garrett
waltchan
07-24-2016 07:37 PM
