lower intake tourqe - Ford Truck Enthusiasts Forums
lower intake tourqe
Old 02-01-2004, 05:36 PM
Racer27
Racer27 is offline
Racer27 is starting off with a positive reputation.
lower intake tourqe
Hello. was wondering if anyone outthere had the torque for the lower Intake bolts on a 97 4.2L AND what side of the engine is the right? looking from behind engine or infront.. my gaskets only fit left and right when you are behind engine.. (as in sitting in drivers seat) this is the right way isnt it???
thanks.. Andrew
Old 02-01-2004, 06:02 PM
Racer27
Racer27 is offline
still need the lower intake torque thanks figured out the engine placement
Old 02-01-2004, 06:37 PM
BlueOvalFitter's Avatar
BlueOvalFitter
BlueOvalFitter is offline
BlueOvalFitter is gaining momentum as a positive member of FTE.
Racer,go to Ajs website and look up the spec sheets on the TSB gaskets. There you will see the new torque specs.
www.leakingfords.com
Old 02-01-2004, 07:17 PM
BlueOvalFitter
Racer,what other torque specs do you need? I have my Ford service manual rite here at my desk.
Old 02-01-2004, 07:22 PM
Racer27
Racer27 is offline
hello blue..
Yes i need the torque specs for the Lower intake manifold bolts.. 6 long ones in middle and the outer shorter ones... the ones that bolt to the cylinder heads.
Old 02-01-2004, 07:40 PM
Racer27
Racer27 is offline
yes there is 8 shorter ones around outer edge of lower manifold...
Old 02-01-2004, 07:42 PM
BlueOvalFitter
Step 1-44 in. lbs.
Step 2-71-102 in. lbs.
My Ford service manual is for 97-99 4.2V6s. The copyrite date is 2/00 I hope this helps.
Old 02-01-2004, 07:45 PM
Racer27
Racer27 is offline
absoultly perfect.. you saved my ***. if i never talked to you i would have had to watch footballl.. LOL thanks very much.
Andrew
Old 02-01-2004, 07:56 PM
BlueOvalFitter
Racer, just to be safe call Ford anyway and make sure those specs are correct. I'm not sure when they updated the gasket torque specs. BTW,i'm watching the game as I type.
Old 02-01-2004, 08:15 PM
Racer27
Racer27 is offline
yupwill call in morning... thanks.
Old 02-02-2004, 04:59 PM
BlueOvalFitter
Racer,were the torque specs correct I gave you? Howmuch do you have left on your motor?
Old 02-02-2004, 05:38 PM
Racer27
Racer27 is offline
hey blue.. never called yet... top end was all put together(within a hour of talking to you... starting on the front cover here shortly.. I bought a haynes manual today... 89inch pound was final in it..i went to 100..I doubt 1 foot pound would make too much of a diff.. but when i go to order the cover gasket i will double check.. to late now so not a big worry if it is wrong..
ANdrew
Old 02-02-2004, 05:59 PM
BlueOvalFitter
In my manual they show the torque spec for the timing cover bolts; 15-22 ft. lbs.
Let me know if these torque specs are correct after you call Ford. If they are not,I need to update my manual.
Old 02-02-2004, 06:24 PM
Racer27
Racer27 is offline
getting at that timing cover is a BITCH.. yup will do.. 15 to 22 ftpounds is what this manual says to.. will double check in morning....
Andrew
avking2508
10-12-2012 07:04 AM
andrewskevich
24
06-21-2012 06:32 PM
Darthange
1997 - 2003 F150
12-16-2009 04:01 PM
Darthange
4 Cylinder Engines
01-22-2005 10:29 AM
TrackStar
03-15-2003 07:40 PM
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
