1978 - 1996 Big Bronco
Synthetic oil
Old Feb 1, 2004 | 03:47 AM
TommyLee's Avatar
TommyLee
Synthetic oil
I just bought my Bronco and it has a small oil leak. Two small quarter size drips in my garage after two weeks. The seller is running synthetic oil. I have heard that synthetic oil can cause leaks in an older engine because it seaps through where regular oil won't. Is this true? Is it OK to switch back to regular oil after running synthetic? I have heard that synthetic breaks regular oil down if it is mixed.
Old Feb 1, 2004 | 03:48 AM
TommyLee's Avatar
TommyLee
Does anyone have a particular brand of oil that they favor or stay away from?
Old Feb 1, 2004 | 05:47 AM
RTM's Avatar
RTM
I have heard the same thing about the synthetic oils. I like Pennzoil. I can't explain the tech reasons but it was explained to me plus I have worked on and rebuilt my fathers engines and he as well uses pennzoil.
Old Feb 1, 2004 | 07:39 AM
Bob Ayers's Avatar
Bob Ayers
Castrol GTX in my gasoline vehicles......
Old Feb 1, 2004 | 07:46 AM
mountravlr's Avatar
mountravlr
Some have recommended AutoRx for various problems. Some users have claimed relief from leaks, etc. after using it. My truck is not leaking from using syn oil.
Old Feb 1, 2004 | 08:02 AM
Corey872's Avatar
Corey872
two small quarter size drips in my garage after two weeks.
In Bronco terms, that is hardly a leak! Surely nothing to be concerned about from an engine longevity standpoint. If it leaks oil, it leaks oil. If you switch to non-synth it may slow down, but I doubt it would stop. The ideal solution would be to find out where the leak is coming from and repair the gasket/seal responsible. Or if the main concern is about the garage, put down a piece of cardboard or oil absorbent mat.
Old Feb 1, 2004 | 12:32 PM
rlh's Avatar
rlh
Dino oils like Valvoline, Mobil, Exxon Uniflo will do just fine as long as service intervals are followed. There is a lot of threads about this sort of thing in the Oil & Lubrication Forum. https://www.ford-trucks.com/forums/f...?s=&forumid=70
Old Feb 1, 2004 | 12:48 PM
kameronth's Avatar
kameronth
I have always had good luck with Vavoline high millage. Pennzoil has parrafene in it and if you ever dig into an engine that used pennzoil it is nothing but gum and gook. That just my opinion.
Old Feb 1, 2004 | 12:58 PM
RTM's Avatar
RTM
My fathers engine had over 250K on it and not a bit of gum. His current engine that I rebuilt has over 300K on it and he hauls with it just about every day so it's not just driven as a daily driver it's used as a work truck.
Old Feb 2, 2004 | 11:12 AM
jimandmandy's Avatar
jimandmandy
The general consensus is that if it leaks at all, synthetic will leak worse, but modern synthetics wont "cause" leaks. The original Mobil One did cause leaks because the Poly Alpha Olefin base oil shrinks seals. Modern synthetics are either non-PAO or have seal conditioners.
Bottom line, you can switch back to conventional and it may solve your problem. Chevron/Havoline are my current favorites. Pennzoil is now owned by Shell and today is excellent, not the same as years ago.
Jim
Old Feb 2, 2004 | 11:34 AM
RTM's Avatar
RTM
This might help some of us?
http://www.corvair.org/chapters/chap...about_oil.html
Major Marvin
46
Dec 19, 2020 08:29 AM
SweetPete531
3.8 & 4.2L V6
Sep 23, 2015 07:37 PM
BillyBob69
30
Jan 9, 2010 12:52 PM
bamacommander
2004 - 2008 F150
21
Jan 24, 2008 08:02 PM
NCF150
1997 - 2003 F150
Dec 30, 2003 10:04 AM
