1978 - 1996 Big Bronco
Keyless entry?
Old Feb 1, 2004 | 12:08 PM
trakman's Avatar
trakman
Keyless entry?
Have a 96 Bronco that has keyless entry. When you push the unlock button, I hear a sound like somthing is either sheared off in the mechanisim or stripped. It will not move the unlock button. Hit the unlock button twice and the other door unlocks normally. Any ideas whats went wrong and what it takes to fix it? This is the wifes and I'd better get it fixed, pronto! Thanks
Old Feb 2, 2004 | 10:50 AM
BillyBob69's Avatar
BillyBob69
You will have pull off the door panel but the linkage usually uses small plastic clips. Take a look in there and you can usually see what broke when you watch it as you try to activate the lock on that door.
Old Feb 2, 2004 | 01:25 PM
wiggit's Avatar
wiggit
Agree with billybob69 did a complete motor on mine takes some patience but not that hard too do.
