Sponsored by: Real Truck
Bigger Tire???
Old May 8, 2002 | 02:14 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Bigger Tire???
Old May 8, 2002 | 08:39 PM
dad4dds's Avatar
dad4dds
Bigger Tire???
Do they give you more traction. Do yo need to recalibrate your speedomiter. Any other things I would need to change with bigger tires.
Old May 8, 2002 | 08:48 PM
NoMo's Avatar
NoMo
Bigger Tire???
Traction is a function of the contact area, the rubber compound and the tread pattern. It is possible for a larger tire to have less traction than a smaller one... and vice versa.
If you change tire size, your speedometer will be incorrect.
Larger tires often require wider rims. Consult the tire manufacturer for the "range" of rim widths they recommend for a particular size of tire.
