Hello Ed,
I'd say stick with the OEM Motorcraft plugs and wires. I am sure there are others that might work, but it seems that some folks experience problems with various other mfgrs. Kind of a hit-or-miss thing.
I replaced my plugs and wires at about 90,000 with Motorcraft parts and it really smoothed things out, just like new!
I bought at a local commercial parts supply house (not the chain store type), not the dealer. Price was about $80 for plugs and wires.
I tried Autolites in my 4.2 once and thought I was riding on a mechanical bull.. It was bucking,jumping,missing and backfired once or twice....I learned the hard way! Been using Motorcraft since then!
BlueOvalFitter-
Not changing the plugs while the engine is hot. Something new for me. Besides not liking to be hot, splain it to me why I should not do this, please.
BTW-I like to apply soapy water to the the recessed area around each plug, then spray the area out with the garden hose on full jet before I remove plugs. I started doing this because it is very sandy where we live and I noticed dirt falling into the plug hole on the wifes Grand Am once. Don't tell her please.
Damon,the heads on the 4.2 are aluminum.The plugs are steel. Add heat to the picture and you are taking a chance of stripping the plug hole or the plug stopping halfway while trying to remove it. Its good practice to do this job while the engine is cold. And,I use a compressor to blow out each plug cavity prior to removal. If you dont have a compressor use air in a can. You can by it at any department store in the electronics sesction.
About the wifes car, i'm sure shes gotten you back while you were asleep!
Originally posted by bunavage Thanks to everbody... It is so nice to have a place to go to get the information before you do the job......Thanks again.....Ed
Glad we can all help each other. It is nice.
I used NoAlox (No Aluminum Oxidation.)on my plug threads. It only takes a small amount to ease install and removal. It prevents oxidation and thread galling - good stuff. Also, I used the dielectric grease in the plug caps.
Nary a problem!
I learned my lesson from straying from motorcaraft plugs....does the same advice apply on wires...or is there a cheaper aftermarket product that will get the job done or do better.?
