Offroad & 4x4
railroad winch?
Old Feb 3, 2004 | 12:47 AM
  #31
Texan1983's Avatar
Texan1983
hoxiii
i know this is alot easier than you think, let me see if i can get the article then i'll post it for you, it's easy, just buy a kit, and a second battery. they run a 24 volt winch on their ultimate super duty in 4wheeler mag. supposed to help you winch run longer heat up less and pull better. all good things.
Old Feb 3, 2004 | 05:29 PM
  #32
hoxiii's Avatar
hoxiii
Less amp draw so less heat, longer pulls. I thought it over and running the 24v winch off of a 12v system would be pretty easy. .
Justin
Old Feb 3, 2004 | 09:17 PM
  #33
99xlt4.04x4's Avatar
99xlt4.04x4
Well, as i learned in physics, its all about the coefficient of friction. Rolling train wheels on tracks dont have too much friction (unless the brakes are on) while four rubber tires on the ground locked up have plenty. The only question is if it would stall out before it got it going. I think it would pull it with out a ****** block.
Old Feb 3, 2004 | 10:38 PM
  #34
hoxiii's Avatar
hoxiii
Apparently he who hesitates is lost. . . Today i went to buy the winch and right as I was walking in another guy was walking out with it in his grubby little hands (more like on his grubby little dolly). Time to go looking again. .
Justin
Old Feb 4, 2004 | 05:08 AM
  #35
13hondacr250's Avatar
13hondacr250
A single man can move a rail car. At the chemical plant they have a bar with a flat end and you stick it under the wheel and pry, repeat at a rapid rate and you can get a rail car moving on level ground. Pretty neat.
Old Feb 4, 2004 | 01:23 PM
  #36
Texan1983's Avatar
Texan1983
sorry to hear that, but there will be others. keep an eye out, at least now you know you can run one.
KC8QVO
Jun 26, 2014 12:56 PM
KC8QVO
Offroad & 4x4
40
Feb 22, 2014 05:29 PM
sumbuddyloanmea.10
Offroad & 4x4
21
Aug 3, 2011 07:49 PM
onug
Offroad & 4x4
Nov 7, 2010 09:43 AM
Robert6401
Offroad & 4x4
Aug 23, 2009 01:06 AM
