ignition
yea, i have the entire dash out, i'm trying to start my truck and i just want to be able to take it out of the dash and leave that part plugged in so i can try and start it. and another question is, i'm not getting any spark, what you guys think that prob is ground?
You're attacking this at the wrong end.
You need to verify power at certain location before you yank out the ignition switch.
Starter relay
*I* circuit on starter relay
Power at coil + terminal
Signal at coil - terminal
Power at Modulator
Signal at Modulator
Spark at Coil
Spark at plug wires
Spark @ sparkplugs
Starter relay
Power at Modulator
Signal at Modulator
Spark at Coil
Spark at plug wires
Spark @ sparkplugs
well i did a down to frame restoration. i just left the motor on it though didn't rebuild it. i put the cab back on and now i'm not getting spark or anything. i just set the dash up their for the time beeing and pluged in the ignition switch and thats not even making it turn over or anything at all. so what do you think it could be then? the battery is hooked up and i'm not getting spoark at the plugs haven't had time to look anywhere else yet
thanks
thanks
bma2001
Sep 2, 2013 09:25 PM
pknute
Jan 29, 2006 01:55 PM
79 250 lariat 4x4
28
Feb 29, 2004 09:15 AM
ITDave
Sep 28, 2003 02:28 PM
