4" downpipe question
Old Jan 28, 2004 | 04:38 AM
spitball's Avatar
spitball
Wondering about the 4" downpipe. Is this a complete new exhaust from end to end, or just changing the downpipe to 4", and what noticable changes occur after modification? Thanks.
Old Jan 28, 2004 | 04:45 AM
Quadzilla's Avatar
Quadzilla
A downpipe is the first section in the exhaust system, similar to a set of headers on a gasser. The benefit of a downpipe is reduced exhaust temps, and less restriction, so you'll be able to develop more power. As with a set of headers, the full benefit can't be felt without replacing the rest of the system with larger diameter tubing, preferably 4".
Old Jan 28, 2004 | 01:46 PM
96P_Stroke4x4's Avatar
96P_Stroke4x4
Smokin'
what year truck do you have? a 4" dp will not fit a '94-'97 without major modding, but a 3"dp will. the 4" dp should fit in a 99+ with little or no manipulation of the firewall, then go 4" the rest of the way back
Old Jan 29, 2004 | 04:47 AM
spitball's Avatar
spitball
I have a 2000, considering upgrading exhaust. Just in the information gathering phase at this time, looking at getting some gauges, but figured getting it done all at once. When changing to 4", are most people leaving the muffler inline? I read a couple of posts where the went straight. I have 3 boys and we use the truck to go everywhere, and the wife will complain if the noise level gets too much higher, so what effect will changing have on that?
Old Jan 29, 2004 | 08:36 PM
Jozey's Avatar
Jozey
94-97 psd can only fit a 3 inch down pipe,and thats a tight fit.I have that on my 96,then from there i have 4 inch exhaust.
Old Jan 29, 2004 | 10:53 PM
bender97f250's Avatar
bender97f250
I run a 3.5" downpipe on my 97, snug fit on bottom of firewall, but it does fit. 4" the rest of the way, minus the cat.
Old Jan 30, 2004 | 12:35 AM
96P_Stroke4x4
Smokin'
thats partially true... a 3" dp usually fits easily, a 3.5" takes a little more work but it will fit, and a 4" will fit with a lot of firewall bending and an ebpv adapter... i have a 4" dp in my '96 and 6" straight pipe out the side
Old Jan 30, 2004 | 05:50 PM
Jozey's Avatar
Jozey
I've seen your downpipe 96,maybe mine is a 3.5 inch but it has almost no clearence from the firewall and the exhaust going behinde the motor.But its the best thing(exhaust)I ever bought for any of my vehicles with the biggest gain.
