Clearancing oil pump?
Old Jan 26, 2004 | 11:31 PM
NoAZ'68's Avatar
NoAZ'68
Hello,
How do I clearance my HV oil pump on a rear sump 351w oil pan? The engine is in the truck. The gentleman at Autozone did not tell me I needed to clearance it and now I have a hole in my oil pan
Any suggestions?
Old Jan 27, 2004 | 02:14 AM
pinellas50's Avatar
pinellas50
Clearencing is done before you put the pan back on. I have always used clay between tow pieces of wax paper.
You bolt the pump on, put you clay on the bottom of the pump(closest to the oil pan), and then install the oil pan. The pan coming down will squish the clay and tell you what the clearance is.
Sounds like this is too little too late at this point though.
Old Jan 27, 2004 | 06:35 AM
TheWiz427's Avatar
TheWiz427
Are you sure the hole came from the oil pump pickup?
Old Jan 27, 2004 | 07:34 PM
NoAZ'68's Avatar
NoAZ'68
Thank you for the replies. No, it did not com from the picup, I believe it came from the corner of the pump itself, perhaps the bolts. If I do take it back, do I even need an HV pump?
Old Jan 28, 2004 | 06:20 AM
TheWiz427's Avatar
TheWiz427
Something does'nt sound right, The pump itself should'nt be hitting the pan. Just where is the hole?
Old Jan 29, 2004 | 12:15 PM
zempman's Avatar
zempman
I ran into this with a 351 I'm building. When I went to install the pan, it rocked on the hv pump. I ground the corners off the pump for clearance, but wasn't enough. I ended up heating the pan with a torch and forming it with a ball peen hammer. I used clay with saran wrap to check clearance.
chincycoot
Aug 30, 2013 06:47 AM
tiger_698
29
Feb 15, 2009 12:32 AM
fire7882
Apr 15, 2008 04:48 PM
apachetech
Oct 27, 2006 03:29 PM
Brizzadd
1978 - 1996 Big Bronco
Apr 1, 2003 01:13 PM
