Coolant boiling over (still)
Old Jul 17, 2007 | 12:19 PM
71FoMoCo's Avatar
71FoMoCo
94 Ranger, 4.0, 5sp. Been having problems with the coolant boiling over into the recovery tank. Replaced radiator with new one last year and had system professionally flushed. Helped for a while, but the problem is back. Sunday I replaced just about everything else with the exception of the water pump and lower rad hose. Replaced heater core, both heater hoses, new tstat (180), upper rad hose. Flushed it all out as well as I could, filled it up with water and radiator flush. Gonna flush it all back out today and refill it with proper mix of water/coolant. The problem is it's still boiling over. The guage never gets hot. It actually reads cooler now, due to the 180 tstat (it had 195 in it before). I just can't figure what the problem is. Maybe gunked up passages inside the block? Could still be something with the water pump maybe... I thought I'd try changing that next just for good measure.
Any ideas? Thanks.
Old Jul 17, 2007 | 04:29 PM
73F100*8Mile's Avatar
73F100*8Mile
I didn't see where you replaced your rad cap. All the symptoms point to that.
Old Jul 17, 2007 | 04:31 PM
71FoMoCo's Avatar
71FoMoCo
Brand new cap last year when the radiator was replaced.
Old Jul 17, 2007 | 04:39 PM
BillC's Avatar
BillC
Also sounds like you might have air trapped in it somewhere.
Old Jul 17, 2007 | 06:41 PM
Torque1st's Avatar
Torque1st
Posting Legend
Check the pressure rise while the engine warms up. You may have a blown head gasket etc a common problem with that engine. Use the proper thermostat, not a 180°F unit.
Old Jul 19, 2007 | 03:30 PM
BChance's Avatar
BChance
Make sure that cap is a 16 lb and have it tested to make sure it will hold it.
ElMoco
46
Nov 28, 2016 09:42 PM
SaintITC
May 15, 2014 03:08 PM
mfire138
Jul 27, 2013 09:02 AM
Buddy03
15
Jun 4, 2012 08:16 AM
sfitzgerald351
1978 - 1996 Big Bronco
64
Jan 15, 2005 04:27 PM
