door ajar
Old Jan 26, 2004 | 10:10 AM
lhmnjck's Avatar
lhmnjck
door ajar
I have a 200 ranger and the door ajar light stays on most of the time I had to take the bullb out to keep from killing the battery.
the doors were all closed and the switches have been tested and read ok with a VOM anybody have experience with this I dont wnat to let the ford equivelent of mr good wrench work on it.
Old Jan 26, 2004 | 11:10 AM
droptop's Avatar
droptop
Try spraying the door lock with WD-40. Do a search for your problem on this site. Common problem with Rangers. Lots of good information on how to solve this.
Old Jan 26, 2004 | 03:24 PM
lhmnjck's Avatar
lhmnjck
thanks for the information. I just found this site by accident.
Old Jan 26, 2004 | 03:51 PM
ChiefsFan's Avatar
ChiefsFan
Same thing happened to me with my old 2000 Ranger and I just sprayed the door switches and locks with WD-40 and it went awa;y.
Old Jan 28, 2004 | 09:34 PM
dougranger's Avatar
dougranger
Same problem others have reported. 98 Ranger Door Ajar light comes on when making turns. Have tried WD-40. Hasn't worked yet. Is it possible to just disconnect the light and chime? I looked in the book for the fuse, couldn't find it. Is there one fuse which would control this chime and light without disabling something else?
Old Jan 29, 2004 | 05:39 PM
Nitrofan's Avatar
Nitrofan
Re: door ajar
Hi guys I'm new here. I have a 1999 Ranger and have had this same problem. It would eventually go off while after having it move. Well came out to my car and the light stayed on and I pulled the fues and voila it turned off. Put it back in for next day's use and it never turned on again. Took it in for service and they said that it needs a GEM module. Anyone know what this is. I also have no 4 wheel drive either and they say they need something else to replace. All be told it will cost me about $900.00
sbappleg8
15
Aug 2, 2017 11:45 AM
GTBksRule
Electrical Systems/Wiring
Apr 22, 2013 01:47 PM
afonda
Jun 15, 2012 12:33 AM
TampaDave
May 5, 2010 05:04 AM
bager
1997 - 2003 F150
Mar 17, 2004 06:55 PM
