1978 - 1996 Big Bronco
would this work!!!
Old Jan 26, 2004 | 02:12 AM
COBRAjrb's Avatar
COBRAjrb
Lightbulb would this work!!!
http://www.ford-power.com/440-396W.htm would this engine do good in a 88 4x4 ford bronco? just curious what evry body thinks?
Old Jan 26, 2004 | 06:00 AM
Chrisvte's Avatar
Chrisvte
For what it's worht, I think that it would do outstanding in am '88!! I have an '88 myself, and wish i had a setup like that!!
Old Jan 26, 2004 | 08:54 AM
94Bronco58's Avatar
94Bronco58
What is the setup?? Street or Off-Road? That is alot of horsepower, and I don't know whether it is too much to where your going to need to do some reinforcing around the frame, and you will probably need a stronger transmission also, but that would have tons of low end power!!
Old Jan 26, 2004 | 10:04 AM
crazed87bronco's Avatar
crazed87bronco
that looks like a good deal does anyone think it will work in my 87 bronco COBRAjrb where did you get those head lights and tail lights
Old Jan 26, 2004 | 12:26 PM
Kemicalburns's Avatar
Kemicalburns
first off is your bronco is fuel injected you will need to upgrade your computer system to mass air. also with that much juice you will need to upgrade your tranny with hd hardware possibly a shiftkit, just dont use one of those electric plug in due dads they suck. also i would contact them about where that engine makes its power. if it doenst kick in until 2500+ rpms then it will hard getting around. you want low end power just and fyi. other then that it looks like a sweet setup.
later
Old Jan 26, 2004 | 03:08 PM
COBRAjrb's Avatar
COBRAjrb
crazed87bronco i got those lights at http://www.procarparts.com well ide like to offroad and be able to tear #@#& up on the streets. 44hp souds like a nice number to me can u explain what kind of renforcing on the frame i would have to do? realy a mass air computer syestems are those spendy kemicalburns? well right now ive got a automatic tranny a c-6 i heard those can take alot of hp but i do relize i have to rebuild it thanks for your help guys and crazedbroco87 check out that site its cool real good prices
Old Jan 26, 2004 | 03:10 PM
COBRAjrb's Avatar
COBRAjrb
440hp lol not 44 lmao sorry i cant type
Old Jan 26, 2004 | 03:15 PM
Kemicalburns
you will not need to reinforce the frame people are swaping 460's into these broncos all the time . so going to a 440hp motor wont make any bit of difference. The mass air conversion can get a bit spendy, figure anywhere between 500 to 1000 bucks. the c-6 is a good auto tranny and can handle a lot but not 440hp with out a build up first. i would just run it and build up after it goes. the c-6 is one of the cheapest to upgrade to. i suggest you go to this site
www.fordfuelinjection.com and speak with Ryan. this guys knows ford EFI real well and can set you up with a mass air kit.
good luck
Old Jan 26, 2004 | 03:44 PM
COBRAjrb's Avatar
COBRAjrb
:} thanks... yea i checked out that engine on that site alittle more and yes the power range is 2500rpm shi t thats not good. any ideas anybody?
Old Jan 26, 2004 | 03:56 PM
Kemicalburns
see if they can tailor it more to your needs. like a different cam and such. let them know its going into a 4x4
Old Jan 26, 2004 | 04:02 PM
COBRAjrb's Avatar
COBRAjrb
yeah that would probaly do it like a diferent cam. maybe edelbrock posibly. hey does any one no anything about jasper engines? i heard they are cool
Old Jan 26, 2004 | 04:08 PM
COBRAjrb's Avatar
COBRAjrb
the stock power at rpm for a 351w does ant body no?
Old Jan 26, 2004 | 04:13 PM
COBRAjrb's Avatar
COBRAjrb
any 351w efi stroker engine building ideas? please share
Old Jan 26, 2004 | 04:27 PM
Kemicalburns
do a search there was a guy in here awhile ago that built a 408 stroker for his dads bronco. also check out ford-trucks.com lots of guys there with plenty of opinnions
Old Jan 26, 2004 | 04:42 PM
crazed87bronco
hey COBRAjrb are these the tail lights that i need for my 87 http://www.procarparts.com/store-lis...ONCO&year=1987
