Sponsored by: Real Truck
Front suspension
Old Jun 9, 2002 | 08:28 PM
Guzzler's Avatar
Guzzler
Post Front suspension
Can somebody tell me what the difference (height & stiffness) between the camper package and a snow plow package suspension? I have a '02 F350 CC, LB, 4x4 v10. Is there any noticable height gain going with the snow plow package?
Old Jun 9, 2002 | 08:46 PM
Quikirk's Avatar
Quikirk
Front suspension
The main thing I noted with the snow plow pkg is that the frt end sits pretty level. If I recall correctly I don't think there's any difference between the snow plow pkg susp and the trailer tow pkg suspension. You still get the heaviest springs with either.
Old Jun 9, 2002 | 08:58 PM
FortyFords's Avatar
FortyFords
Front suspension
As stated The x springs(snowplow pkg) will level the truck front to back
You also get the steering stabilizer.
Trailer tow pkg gives you wired plugs and trailer hitch (frame mount)
I have all of the above with 8800 lb gvw pkg
Rich
Ford Trucks Built Tough!
Not like all the rest!
Old Jun 9, 2002 | 10:25 PM
Monsta's Avatar
Monsta
Sit. Stay.
Front suspension
OI I've got a headache! I can't remember...BUT the Camper package includes the heavy service suspension which is NOT (I believe) the X springs up front. X springs are (for the truck in question) just for the plow package and the V springs are for the heavy service package. Now with this headache, I could be wrong...so correct me if I am.
The camper package also adds the rear sway bar and certification label which the plow package does not.
SInce the V code springs are 5200lb springs and the X springs are 6000lb springs, the truck with the plow prep package will be more "stiff".
Old Jun 10, 2002 | 05:03 AM
Yeti's Avatar
Yeti
Front suspension
Headache??? don't tell me the wife wouldn't let you put that muffler on her EX??
Anyhow, Monsta is correct, X springs are the stiffest springs available and like FORTY said ,do almost level the truck.
Old Jun 10, 2002 | 07:56 PM
4x4x4x4's Avatar
4x4x4x4
Front suspension
[updated:LAST EDITED ON 10-Jun-02 AT 09:52 PM (EST)]Here's what I have from a couple of Ford Publications.
1.From the 02 Ford RV and Trailer Towing Guide...
Super Duty F-250/350 Camper Package (Option Code 532)
A. Heavy service front springs(200lb.upgrade over springs computer- selected based on options ordered.Not included if maximum springs already selected.)
B. Rear stabilizer bar(SRW models)
C. Slide-in camper certification
2.From the 02 Ford truck brochure...
Suspension Package,Heavy-Service (Option Code 674)
Heavy service front springs,steering damper.Recommended only on vehicles which will permanently utilize aftermarket equipment which loads the front axle to the specified gross axle weight rating (GAWR).
3.From the 02 Ford truck brochure...
MAX.Front GAWR Package (Option Code 682)
Highest front GAWR springs,steering damper.
(May result in a deterioration of ride quality.)
4.Form the 02 Ford truck brochure...
Snow Plow Package (Option Code 86M)
Highest front GAWR springs(5200lbs.),steering damper.
See Supplemental Reference or Body Builders Layout Book for details.
I hope this may be of some help.I suspect that the order info.book that the dealer has gives a better explanation of the last three pkgs.I listed and their individual differences.
Old Jun 12, 2002 | 09:35 AM
NoMo's Avatar
NoMo
Front suspension
Here's a summary of what others have said after converting to "X" springs:
The plow pkg gives 1.0 to 1.5 inches of "lift".
There is a small, but noticeable, difference in ride.
Old Jun 12, 2002 | 09:43 AM
NoMo's Avatar
NoMo
Front suspension
Aquik72
Dec 9, 2009 07:38 AM
burgf250
Dec 27, 2007 10:49 AM
ultramag
Oct 16, 2007 08:22 PM
volfan79
Sep 24, 2004 04:51 PM
fordowner4life
Dec 10, 2003 01:05 PM
