Thanks Rb and Gunfighter for all your help on this. I did end up finding thh Jordan site and I did also take a look at the Prodigy Tow Card.
Thus far the with reading I have done is seems that some of the perks of both may be the same just done differently.
In the prodigy you need to use the boost functions as the fine tune so the brakes on the trailer will be more sensitive to operate so when you hit the brakes on the truck the trailer brakes begin slowing you down a bit before the truck brakes, which I feel would be Ok.
In the Jordan you may have a bit more contol off the pedal and then you fine tune with the amp dial to get you dialed in. Nice. On the Jordan do you have to do any leveling?
I hope I did a good job explaining if not any help would be good, but this is the way I am interepreting it this far.
Well I guess I am going to have to keep reading., but clearly these two are some of the best and highly recommended that I have seen.
Thank you all for your posts. I have printed everything out for my records and will keep on reviewing the information unitil I can make a decision. If I need anymore help I will let you all know. Thanks again
