1978 - 1996 Big Bronco
Replacing U-joints?
Old Jan 24, 2004 | 12:16 PM
89Bronco_EddieBauer's Avatar
89Bronco_EddieBauer
Do I have to remove the entire front axle assembly to replace the wheel joints?
Ok, I went to a mechanic shop to have my two front wheel joints [U-Joints] and my front and rear U Joints replaced. The mechanic told me that he had to remove the axle and the entire hub assembly to replace the Wheel Joints. Is this correct?
He also said that the total amount of labor thats going to be invloved in replacing the front wheel joints is One Hour each side.
Am i getting flamboosled here?
I wont bring the truck in untill i hear it from you guys first.
Oh, the truck is a 89EB 351W.
Old Jan 24, 2004 | 02:58 PM
bremen242's Avatar
bremen242
One hour for replace the ujoint on one side seems about right to me. It is fairly involved.
You have to take off the hubs, rotors, and then the spindle, then you have to pull out the axle shaft from the diff or the slipyoke, depending on the side.
Old Jan 24, 2004 | 03:03 PM
89Bronco_EddieBauer
Ok good.
Is there anything else I should consider replacing while he has all that apart??
Old Jan 24, 2004 | 03:57 PM
BillyBob69's Avatar
BillyBob69
Ball joints. Tie rod ends...they have to take them apart as well to get the axle out. May as well have them done while its all apart anyway.
Old Jan 24, 2004 | 04:33 PM
BroncoMTR's Avatar
BroncoMTR
I am going to be needing similar work done in the future. How much do you think the whole job would cost, ball-joints and u-joints? How feasible is it to do yourself, for a average guy with basic tools? Also, considering an add-leaf in the rear, which I am planning to do myself, any particular insight on that? Never done it before.
Old Jan 24, 2004 | 06:32 PM
bremen242's Avatar
bremen242
btw, they _don't_ have to remove the tierods or balljoints to do the ujoints.
I'd say it'd add another 1 to 1.5hr each side to do tierods and balljoints.
you can do it, it takes a good while to do it, and you'll have to buy a few tools (ie 1-5/16" open end wrench and a 1-1/8" 6 point socket, and a balljoint seperator). If you unsure about doing an add-a-leaf, you probably shouldn't do the ball joints unless you have another car / truck to drive.
Old Jan 24, 2004 | 09:34 PM
BillyBob69's Avatar
BillyBob69
Well true..they dont need to remove em...but once they get the axel out all that is left is 3 bolts...and some pounding.
It is feasible to do them your self. I just finished mine about an hour ago..took me the day. Had I taken it somewhere...I would of been charged about 550 bucks with parts. Without parts, about 325. Now you see why I decided to do it myself. It is a pain but it can be done. Now all I need is to get an alignment.
Old Jan 25, 2004 | 03:51 AM
blrman1962's Avatar
blrman1962
I did my ball joints and u joints on the axles in an afternoon if you have a good vise and a bug hammer no problem just be patiant it will come apart I also changed the spindle bearing and wheel bearings,drag link, and tue rod ends. As long as it is all apart I just did it all. cost me in parts around 350.00 If I did it at a shop it was over a thousand. There is a great savings to do it yourself. plan on a whole day or a little more. This site is a great help if you run into any problems. DO your self a favor an get good parts TRW or MOOG you will only want to do it once good luck Peter
Old Jan 25, 2004 | 09:59 AM
bremen242's Avatar
bremen242
Its definately a lot easier when you have tools. it took me a little while, cause I had to run to sears like 5 times for tools..
Old Jan 25, 2004 | 12:29 PM
BillyBob69's Avatar
BillyBob69
LOL Oh I know that feeling BREMEN. Gets realy bad when you walk into the parts store or tool store and they know you by name.
