Sponsored by: Real Truck
Under Bed Spare
Old Jun 5, 2002 | 11:54 AM
99 sd v10's Avatar
99 sd v10
Under Bed Spare
I bought my truck used. It didn't come with a spare or the hardware for a spare. I assume this is normal for heavy duty trucks. I don't know for sure. Do you guys carry spares under bed?
I wouldn't mind getting the hardware to put one under bed. I don't know if there's enough room for my tire size. Anybody with experience here?
Steve
99 SD, V10, EC, SB, LARIOT.
315-75-16 ProComp XTerrains M/T ClassicII 16x10
Fabtech 3.5 lift kit
More to come I'm sure.
Old Jun 5, 2002 | 01:17 PM
UNIMOG's Avatar
UNIMOG
Under Bed Spare
All the Super Duties I have looked at have the spare tire mounted under the bed (standard, not optional). The Excursions have their fuel tanks mounted in that location, since they store their spare tire "indoors".
If you bought your truck with the 315/75x16 already on, perhaps the prior owner removed the spare, since it looks like from postings to this board, that 285s are probably the largest tire you can fit under the bed, in the stock location.
I've been kind-of chomping at the bits, at the idea of adding an Excursion's 44 gallon fuel tank in this location, to supplement my wimpy 29 gallon tank (short bed). I'm also running 315/75x16 (no lift), and my stock 235 spare would be pretty lame anyway if need.
Mark Peterson
'02 F-250 CC,SB, V10
(eyeing a Kenne Bell supercharger)
Old Jun 5, 2002 | 01:46 PM
rob_n_houston's Avatar
rob_n_houston
Under Bed Spare
Also bought mine used with no spare. The previous owner had put 33's on 10" rims. I bought a used rim and tire and mounted it under the bed myself. No special hardware (bought from Ford), just a couple 1/2" all threads and some nuts.
BTW I did have to use it Memorial day when one of my tires developed a bulge. I couldn't drive over 35 mph without shaking the truck apart (plus the tire could blown at any time). Haveing that spare 125 miles from home was a life saver. I think my spare is a 235 65.
Rob
Old Jun 5, 2002 | 06:50 PM
thewhiteford's Avatar
thewhiteford
Under Bed Spare
With a Lariat package, it should of come with a spare. Who knows what happened to it, but I can't imagine the truck NOT coming with one from the factory.
Old Jun 6, 2002 | 10:47 AM
99 sd v10's Avatar
99 sd v10
Under Bed Spare
I was the one who put the larger tires on. I would like a tire the same height. I wouldn't mind it being narrower though. Then again a exact replacemnt to the set I have would be good even on a different rim. I suppose I coulld take one off the truck and floor jack it up to see if it'll fit.
BTW I saw no signs of this truck ever having a spare or the hardware for mounting it.
Steve
Old Jun 14, 2002 | 01:15 PM
harald's Avatar
harald
Under Bed Spare
I factory ordered a 99 F350 back in April 98. I thought I was getting one of those mini spares because the Kelly Blue book page said it came with the truck. Upon further research, I found that the spare was an option back then. I ordered the crank assembly and a steel rim and simply bought a tire from Firestone. I don't know how big you can go, but it does seem tight under there for the stock size. The crank assembly looks like it would work with any tire size; you're just limited by tire diameter hitting frame parts before it goes all the way up.
Harald
2000 F350 4x4 CC DRW V10 4.30ls Lariat LWB.
Firestone Ride-rite airbags, Rancho RS9000 shocks and Torklift Superhitch.
1998 Alpenlite Pendelton 11'10" camper held on by Torklift tie downs.
Old Jun 15, 2002 | 02:08 AM
LW555's Avatar
LW555
Post Under Bed Spare
Hey Steve, I removed the stock tire mounting hardware from my truck because my spare is now in the bed. I'm not sure if the mounting locations would be the same on '99 vs '02, but if you think it would fit and you want it, you can have it, I'll never need it.
Lee
Old Jun 15, 2002 | 09:55 AM
FortyFords's Avatar
FortyFords
Under Bed Spare
Old Jun 15, 2002 | 10:43 AM
99 sd v10's Avatar
99 sd v10
Under Bed Spare
Hey thanks!!!
I'll need to measure to see if the tire will fit. I would like the same size spare as the set I'm running. I could as a less ideal situation run one of my factory tires for a spare.
I'll check it out so I Know what I can do.
Steve
DirtyLarry
17
Apr 22, 2019 11:45 AM
steve340
42
May 24, 2015 10:24 PM
SteveW84RC
Modular V10 (6.8l)
22
Sep 21, 2014 08:12 PM
99StrokeXLT
Aug 20, 2014 07:03 AM
Doc
Jun 30, 2011 11:57 AM
