1978 - 1996 Big Bronco
35's on a 81
Old Jan 23, 2004 | 11:02 PM
ba 302's Avatar
ba 302
35's on a 81
is it possable to slap 35's under a stock 81 how much cutting would you have to do or is it easy to put in a body life anyone have info on this,
Old Jan 25, 2004 | 02:47 PM
bronco up's Avatar
bronco up
I would not attempt the 35's, 33's will rub on a stock suspension when off road. Far as the body lift, some will tell not too and some will say there fine. They are cheaper and do not change your ride but will handle allittle different. I have a 4 inch suspension along with a 3" Body running 33's, but I like the looks of alittle fender well...Pretty easy to install, get a buddy to help and can be done in about 4 hrs.
Old Jan 25, 2004 | 03:13 PM
acerockola77's Avatar
acerockola77
You will deffinately need to put a lift on it to fit 35s.
Old Jan 25, 2004 | 04:23 PM
ba 302's Avatar
ba 302
the reason I ask if I can get 35's under is because I have 33's on now and it still looks like I have alot of room and the only rubin I get is on the in side of the traction bars when I crank the wheel. but I think I'm going to go with a body lift any way now on a 3" lift what is involved in this mod?
Old Jan 25, 2004 | 09:22 PM
justshootme84's Avatar
justshootme84
Don't forget that the huge gap disappears when the suspension flexxes or when you try to turn. I have a 6" susp lift and my 35's will still touch the fenders now and then. I personally would not run this size tire without a susp. lift, cause you get some stronger components with the kit to handle the added weight of the big tires.
As for the body lift, you simply add spacers to the ten body-frame mounts, cut the radiator shroud, and may have to extend the steering shaft and shift linkages on the tranny and transfer case. Some kits also come with brackets to raise your bumpers up to match the body. The hard part is working on the body mounts, esp. if they're rusted.
MavSprint
Aug 4, 2013 06:55 PM
Captbs32
24
Jan 25, 2012 09:58 PM
Todd's81ford
Oct 21, 2011 02:44 PM
gozu81
Jan 24, 2011 11:38 PM
ford_muddbilly81
Apr 4, 2006 01:24 PM
