Headers and starter
Old Jan 23, 2004 | 10:49 PM
elstx's Avatar
elstx
Headers and starter
I've come to the realization that even if I manage to get my headers unbolted from the exhaust manifold, I still can't get my starter out.
Anyone know if it's possible to unhook headers from tell pipe, push them out enough to get starter out?
Old Jan 23, 2004 | 10:57 PM
Fritolay's Avatar
Fritolay
it is possible to get it out once the headers are off just get em loose and then tie em toward the fender with a hager around the frame. and my advise for the boltsis extensions and extensions and the get a few more extensions i tightened my starter bolts while standing in front of my truck. (learned that one pulling starters on ARMY pc's)
Old Jan 23, 2004 | 11:20 PM
elstx's Avatar
elstx
Are you saying I have to loosen the exhaust manifold bolts?
Old Jan 23, 2004 | 11:32 PM
gtex's Avatar
gtex
Headers are bolted to the heads. Do not remove the heads to get the starter out. Worst comes to worse, unbolt the headers from the heads, undo the engine mount from that side of the engine and lift that side of the engine if you have the equipment to do so (watch for clearance issues elsewhere around the engine). Engine hoist is best, others have done it with floor jacks and lumber. This is one way to get some space to work with.
Checking for understanding, you do have headers , not stock exhaust log style manifolds, correct?
How are the headers connected to the rest of your exhaust. You should be unable to disconnect them there and get more space to help remove the starter, possibly without liftin one side of the engine.
Good luck..
Old Jan 24, 2004 | 12:00 AM
Fritolay's Avatar
Fritolay
sorry for any confusion i menat for the starter bolts use a couple long extensions (tape em together if they dont lock) and you can get to the starterr bolts a lot easier
Old Jan 24, 2004 | 12:05 AM
Faithful Old Road Dog's Avatar
BTW. Make sure you disconnect the + side of the battery first.
Old Jan 24, 2004 | 12:41 AM
elstx's Avatar
elstx
Understand you on the extensions now - good idea.
Yes, I have actual headers. I'm soaking the exhaust manifold bolts now with Liquid wrench.. I tried turning them, and was just twisting the head. As far as getting the starter from where the headers connect to the exhaust pipe, the headers end after the starter, making that impossible. I'm really looking at a big job for a $30 starter.
I don't have a hoist or lift. Just a driveway and a daughter that is turning out to be a good mechanic.
Old Jan 24, 2004 | 08:56 AM
gtex's Avatar
gtex
I'm not sure if you understood what I was trying to say. If you can unattach the header at the collector (where the header connects to the rest of the exhaust plumbing), and at the heads, you should be able to position the header out of the way to help get to the starter.
take your time on the exhaust header bolts. It sounds like they are in bad shape. Use the lube and tap the bolts a little. Use a low-torque 3/8" air ratchet if you have one available.
Old Jan 24, 2004 | 12:08 PM
elstx's Avatar
elstx
I got what you're saying now. I'm soaking the header bolts as we speak. Looks like I will have to saw it somewhere at the bottom where it connects to the exhaust pipe.
Old Jan 24, 2004 | 12:12 PM
gtex's Avatar
gtex
That sound extreme. You might explore lifting that engine side first. I guess your exhaust is welded up, no flange at the end of the header?
Old Jan 24, 2004 | 01:13 PM
elstx's Avatar
elstx
Yes, it's welded. Looks like whoever did it, wanted to make sure nothing came loose.
Old Jan 24, 2004 | 03:32 PM
gtex's Avatar
gtex
I did hat on my 390 with Dynomax headers, just because they fit so bad and we could not get them to seal....
You may be able to loosen the entire exhaust plumbing..cutting it sure makes a mess.
Old Jan 26, 2004 | 04:38 PM
soutahranger's Avatar
soutahranger
I just did this job yesterday on my '68 f100. I pulled the headers from the block. After listening to your troubles on another post I thought they would be difficult. My header bolts came out with a regular ratchet and a minimum of effort. I guess I was lucky. My headers ended at a flange. I had to disconnect that end as well to get the starter out. I don't know what to do if the headers are welded into the rest of the exhaust system. I would suggest lossening the entire exhaust mess to see if you can get a little more space. Good Luck.
Old Jan 26, 2004 | 05:01 PM
seventysixer's Avatar
seventysixer
If the guy before you did the right thing he used anti-sieze compound on the bolts. This is to prevent them from becoming a rusted up mess. Make sure you do the same when you re-install, it's cheap insurance for next time.
tartar_sammich
29
May 31, 2015 04:17 PM
FLgargoyle
Mar 3, 2014 08:42 AM
deereman2
Mar 24, 2008 01:59 AM
Chris_ce
Jun 12, 2005 02:03 PM
92F150XLT
Jun 4, 2005 11:42 AM
