D@mn Trani!!!
Old Jan 23, 2004 | 05:36 PM
tripslip's Avatar
tripslip
D@mn Trani!!!
Hey y'all,
I could use some advice.
I just got done installing my engine after a rebuild and now my tranni is acting up.
When I pulled the engine the tourge converter came out with the engine even though I removed the fly wheel bolts and tranni fluid went everywhere.
Now I have a leak out of the flywheel cover and it jumps in and out of drive but goes into rev. fine. It I keep the RPM's up, it will stay in drive.
Anyone got any ideas? Cuz man, I'm about to throw tools and I dont want to do that!
Thanks!
Old Jan 23, 2004 | 07:25 PM
Opera House Works's Avatar
Opera House Works
I would be concerned that the torque converter was not fully seated. TC must be on the transmission when installing. The TC has three engagements and if a yardstick is placed accross the face, the TC pilot should be over 1/2 inch back from the face. Did you have to use the bolts to pull the transmission in? If so, that is very bad. Sounds like the front seal could have a slice in it now.
Old Jan 23, 2004 | 07:36 PM
tripslip's Avatar
tripslip
yes i did use the bolt to pull it in but it gave no resistance. but I did not check to see how far the TC was it before I installed the engine.
I'm begining to wonder if I have a vacuum leak also.
banicman
Feb 13, 2013 07:27 PM
bliss1
Computer Chips & Tuners
Sep 13, 2008 10:01 AM
dalkins1
Jun 16, 2007 07:39 AM
Munkey
Modular V10 (6.8l)
39
Mar 7, 2006 11:39 AM
cjben
Feb 13, 2003 05:50 PM
