High Idle
Old Jan 23, 2004 | 12:16 PM
DonnyT's Avatar
DonnyT
High Idle
Hello
I have a 1988 F150 4x4, 5.0L. It is idling very high and will maintain 32MPH with foot off the accelerator. I cleaned the the throttle plates. I noticed (finally) that I had no Check engine light when starting the truck. I found that there was no bulb in the check eng lamp holder (sold to me thaty way). I installed the bulb and I now get a flashing check engine light when accelerating (ocasionally). I wanted to read the codes myself using the check eng light or a meter. Where is the test connector and what pins do a short and are there any other troubleshooting advice for the high idle.
Old Jan 23, 2004 | 06:07 PM
AllFords1022's Avatar
AllFords1022
i have an 87 f150 with a 5.0, dthe diagnostic hook up is on top of the right fender, its an orange box and it will say diagnostic on it but first off i would check for a major vacumn leak, like a pcv line fell off or one near the brake booster. good luck, post back let us know what you find
Old Jan 24, 2004 | 03:50 PM
homerstud's Avatar
homerstud
I had a similar problem and it was the PVC hose!
Old Jan 25, 2004 | 11:57 AM
RA020626's Avatar
RA020626
Banned
My '91 had similiar symptoms. I found the plenum-to-intake gasket tatered. an $8 gasket set and 2 hours to replace the plenum gaskets fixed all. I reset the PCM to erase the attempts to correct A/F ratio as well.
Old Jan 26, 2004 | 10:23 AM
DonnyT's Avatar
DonnyT
Thanks for all the input. It was the upper intake gasket. It looked as if it was going bad for quite awhile.
FlyCool5.0
Nov 13, 2013 11:26 AM
darrelllee
1983 - 2012 Ranger & B-Series
Apr 7, 2011 07:34 AM
SueEmAll
Jan 21, 2006 06:15 PM
capstan
Apr 14, 2005 07:31 PM
mgb150
1997 - 2003 F150
Oct 27, 2003 08:22 AM
