iacv
Old Apr 6, 2011 | 08:42 PM
darrelllee's Avatar
darrelllee
iacv
i have a 1999 ranger with a 4 cyl eng my check eng light came on went to auto zone they said it neded a idle air control valve. got new one and installed it drove it and check eng light came back on.can you tell what else it might be --thanks,darrell
Old Apr 6, 2011 | 09:20 PM
pawpaw's Avatar
pawpaw
Welcome to FTE.
What was the trouble code Number they pulled???? If you don't have it, have them scan the computer again, get the trouble code Number & post it here & we'll see if we can come up with a diagnosis. Dont buy anything else until you work up a reasonable diagnosis.
Any additional clues on the vehicles behavior that you can provide will likely be helpful.
Also how many miles on it & where you are on all past & present due scheduled maintenance & any repairs in the past.
Did this problem come about suddenly after some event????
Old Apr 6, 2011 | 10:13 PM
darrelllee's Avatar
darrelllee
iacv
how does p1506 sound or p156 or c1506
Old Apr 7, 2011 | 07:34 AM
pawpaw's Avatar
pawpaw
P1506 is for high idle speed & suspecting the IAC is reasonable, as it's a common problem part, But other things can also cause high idle speeds.
Like an electrical problem to the IAC, sticking open IAC, I know you said it's new, but that doesn't automatically make it good, because they're not 100% tested, if they're tested at all, computer problem, acting out evap system, vacuum leak & this would include a stuck open PCV valve or leaking connection to it & all other vacuum sources, dirty sticking open throttle plate, binding throttle cable ect, ect. So you need to look deeper & check the things listed.
More thoughts for consideration, let us know what you find.
FordRun
Apr 26, 2014 10:56 AM
freds
1997 - 2003 F150
Feb 23, 2007 07:50 AM
tango54464
Sep 14, 2006 06:02 AM
capstan
Apr 14, 2005 07:31 PM
bkc1964
Dec 31, 2003 09:02 AM
