78-79 engines
Old Jan 23, 2004 | 07:51 AM
torquemeister's Avatar
torquemeister
78-79 engines
Does anyone have a list of the engines that were available in the 78 & 79 F150's (it has the XLT Lariat Ranger trim package, if that matters on the older trucks).
Thanks,
TM
Old Jan 23, 2004 | 08:34 AM
FordBoypete's Avatar
FordBoypete
Thumbs up Engines available in 78 &79 F 150s....
Sure . . . .
300 I-6
302 & 351 Windsor V8s
351M/ 400 V8s (Commonly called "Modifieds")
460 Cid series 385 V8's
FBp
Old Jan 23, 2004 | 09:07 AM
ranger429's Avatar
ranger429
Torquemeister are you trying to figure out what motor you have in the truck? Is it a 4x4?
460 was only available in a 2WD
the 302 and the 351w have a bypass hose on the thermostat housing and also 6 valve cover bolt's
the 351m/400 has no bypass hose and has 8 valve cover bolt's
the 300 well you probably figured that one out
Also the trim package has no bearing on what motor could be in the truck
Old Jan 23, 2004 | 10:57 AM
trucksforever's Avatar
trucksforever
wasn't the 390 available too? or did they quit the 390 after 77.
Old Jan 23, 2004 | 11:18 AM
4byford's Avatar
4byford
360/390s were last available in the 76 model year; 77 was the first year for the 351M/400
Old Jan 23, 2004 | 01:24 PM
torquemeister
thanks for the replies!
i don't have the truck (not yet, anyway). Someone down the street is selling it - it's either a 78 or a 79 based on the front grille, so i was wanting an idea of what engine might be in it (the for sale sign says that it does not run - i don't want to go into it blind when i go look at it). my 86 is the oldest truck i've worked on, so i don't know much about any of the differences between the late 70's trucks.
Thanks again,
TM
Old Jan 23, 2004 | 04:15 PM
Mil1ion's Avatar
Mil1ion
The letter H as the 4th character in the Vin# is the 351M
S is the 400
J is the 460
Also,
The 351W was not in the engine line-up 78/79.
The only 351 was the 351M
There is enough info on this thread to identify it.
Old Jan 23, 2004 | 07:31 PM
fordeverpower's Avatar
fordeverpower
The older trucks are fun to work compared to newer crap.
Old Jan 23, 2004 | 09:52 PM
ranger429's Avatar
ranger429
Also, The 351W was not in the engine line-up 78/79.
HUH?? A friend of mine had a 78 stepside F150 4x4 with a 351w in it. I do believe it was factory that way
Old Jan 23, 2004 | 09:59 PM
Colo79Ford's Avatar
Colo79Ford
i have heard that only Customs had 400's in them in the 70's...dont know if that is true though.....
Old Jan 23, 2004 | 10:03 PM
Mil1ion's Avatar
Mil1ion
No original 351W in 78.
Here are the engine choices for 78.
I hope it's legible.
This one is from the Ford Specs pamphlet.
It has all the engines listed & identifies the 351 as an M engine.
http://mil1ion.clubfte.com/78Calibra...e-upSpecs.html
From the Vin# decoder.
http://www.clubfte.com/users/mil1ion...ruckCodes.html
Old Jan 24, 2004 | 07:37 AM
ranger429's Avatar
ranger429
WOW I certainly thought he had the W block in there. After looking at your chart I see they had the 302 in the F-150, must be what he had.
I also see in the link they offered the 351W in the F-100 chassis under the 351M class for Calif. only.
Old Jan 24, 2004 | 10:00 AM
F150daniel's Avatar
F150daniel
I dought the 351W was even produced in the late 70s.
beside they all ready had a 351, why have two different 351s optional?
Old Jan 24, 2004 | 10:08 AM
F150daniel's Avatar
F150daniel
Mil1ion
thanks I was looking for that site again.
https://www.ford-trucks.com/framered...ruckCodes.html
Old Jan 24, 2004 | 10:33 AM
F150daniel's Avatar
F150daniel
"it has the XLT Lariat Ranger trim package"
you mean Ranger Lariat
they did not make a Ranger XLT Lariat
the trim options were
Custom
Ranger
Ranger XLT
Ranger Lariat (rare)
