New multi-function switch in a 89?
Old Jan 21, 2004 | 05:53 PM
Mustang 5.0's Avatar
Mustang 5.0
I'm a bit tired of stomping the floor to switch high beams and reaching for the wiper switch on the dash.
Has anyone installed a multi-function steering column assy onto a 89's column to give us the one-stalk-does all features?
Old Jan 21, 2004 | 06:37 PM
garysvan's Avatar
garysvan
i am sure it could be done if you are good at fabricating. doing some cutting and adaptation to get a stalk like that to fit the column. then there is the electrical side of it most likely you would have to use some relays to do some of the switching i think that is how most of those stalks work because the switches are fairly light duty. would be a challenge but could be fun if you like to customize. i would say time to go to the you pull it yard and do some research for a donor vehicle.
Old Jan 21, 2004 | 08:00 PM
Mustang 5.0
Yah. the wiring doesn't give me much heartburn. Mechanical is my biggest concern as the steering column must be able of cancelling the turn signals.
Do the E-150's have multifunction switches? if so, what year (and model) were they first installed?
Old Jan 23, 2004 | 01:17 PM
IJRoorda's Avatar
IJRoorda
'92 was the first year the E-150's had multi-function switches. I think the dash stayed mostly the same through '95 or '96, and then in '96 or '97 they got a new dash with a different multi-function switch.
Hope this helps,
Isaac
Old Jan 23, 2004 | 05:16 PM
Mustang 5.0
Thanks for the info. I'll head out to a yard and see what I can see.
PStruwing
15
Nov 9, 2015 06:17 PM
firewood truck
Mar 17, 2012 01:46 PM
al_huryn
1978 - 1996 Big Bronco
Mar 14, 2007 07:51 PM
steve 1520
2004 - 2008 F150
Feb 26, 2006 08:53 PM
el conquistador
1983 - 2012 Ranger & B-Series
13
Apr 7, 2005 09:50 PM
