1978 - 1996 Big Bronco
Transfer case won't engage
Old Jan 21, 2004 | 02:48 PM
IM1096's Avatar
IM1096
I'm having trouble with a '95 Bronco 4x4 with push button transfer case controls. The automatic hubs were replaced with Warn manual hubs. The trouble is when I push the button for either high or low range four wheel drive nothing happens. The fuse in the panel is good, is there a relay or alternate fuse somewhere else?
Old Jan 21, 2004 | 05:24 PM
Corey872's Avatar
Corey872
If you mean "nothing" as in no clicks or anything at all, you may look behind the instrument panel and make sure the switch is plugged in. When I got my truck, I think some bozo had the dash out (which more and more I believe was to roll back the odometer), the switch was unplugged. I think there is only one fuse to the control unit.
If you hear clicks but no engagement, that is most likely electric motor troubles on the case. Lastly you have to be in 4-hi to go into 4-lo...pushing the 4-lo button doesn't do anything unless you are in 4-hi, stopped, and in neutral...only then do you get 4-lo.
Old Jan 21, 2004 | 06:13 PM
IM1096's Avatar
IM1096
I've checked the plug behind the dash panel, no problem there. This Bronco was bought new and has been in four wheel drive maybe 4-5 times total since it was new. I get "nothing" when I push the buttons to engage the t-case, no lights, no clicks, nothing. I hate the thought of having to take it to a shop if it's possibly a simple fix!!!
Old Jan 21, 2004 | 06:58 PM
Black Ford XLT's Avatar
Black Ford XLT
Transfer Case
I--m this post is to help u diagnose this problem read all of it ,Refers to explorers but has the same shift motors our broncos have.Beleive me if u take it to a shop get ready for the $$$ charge.Its good info and pertains to your problemsand u can actually do it your self. Theres a diagnosis check to see if its your controller or shift motor ---copy this well worth its weight n gold if u plan on keeping your ride TR http://www.glue.umd.edu/~singletn/web/pages/tcase.html
Old Jan 21, 2004 | 07:53 PM
IM1096's Avatar
IM1096
Thanks Black Ford XLT, very informative articles, I should be able to diagnose and cure the problem from the info included in the link.
Old Jan 21, 2004 | 08:06 PM
Black Ford XLT
4x4
Im in your kick panel passengers side is your controller ,theres a button on it to see if its your controller acting up or shift motor.U have to undo 2 of the three(elect) hook ups(info tells all).The motor on the transfer case isnt hard at all to drop.Ive had mine off 2 times.I even bought a used one from a junk yard and 2 extra controllers (all for 80$), and all work.Parts for our trucks are getting harder to find ,and they say a new shift motor can be between 300-500 bux with the controller from ford 400$$Good luck TR
Old Jan 21, 2004 | 08:13 PM
IM1096's Avatar
IM1096
I was wondering where the controller was, should have no trouble finding a fix to the problem.......... thanks again for the info.
Old Jan 22, 2004 | 12:46 AM
bigric's Avatar
bigric
The controller is behind the passenger kick panel. Since you're not hearing clicks or anything, that's probably where you should start.
I pulled my motor a few days ago and replaced the rotted-out travel stop with a 1/8" piece of 5/16" fuel line. Total time was about 20-30 mins and it fixed my problem. That is a great article, although I thought that it made things sound a lot more complicated than they are. Those motors only have about 5 distinct pieces in them.
Old Jan 22, 2004 | 08:52 AM
IM1096's Avatar
IM1096
Thanks bigric, I'm just walking out to the shop now to get started, I'll let you know how it turns out..........
Old Jan 22, 2004 | 12:19 PM
IM1096's Avatar
IM1096
Just a quick update, followed the instructions on how to check the tcase motor and actuator, I put it all back together and it works like new!!!!!!!!!!!!!!!!!! Thanks to all who offered advice, you guys saved me a lot of $$$$
Old Jan 22, 2004 | 07:08 PM
Black Ford XLT
Thumbs up 4X4
Glad you got it fixed ,Im ,especially since this site seems complicated , Its simple actually TR
