oil dipstick
Old Jan 23, 2004 | 02:26 PM
$trokin60's Avatar
$trokin60
I took mine back to dealership for fuel in oil when the tech pulled the dipstick the handle came disconnected from the wire portion so they ordered me a new one when it came in it was grey it is a little esier to read than the black one same part number as the old one just luck of the draw
Old Jan 23, 2004 | 03:07 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
I am amazed, I figured it would have been considerably easier........hum
Old Jan 23, 2004 | 04:00 PM
SBV45's Avatar
SBV45
I have the part number at home. I will post it this evening.
No, I didn't pay for it. It was warranteed.
I pulled on the T handle and it came off. The rest of the dipstick stayed right there sticking up about 1/8" above the tube and I pulled it out with a pair of long nose pliers. I ddn't want to leave it there and run the risk of it sliding down into the crancase.
As far as the tow/haul mode with the latest flash, I understand that in top two gears the torque converter is no locked in tow/haul mode until you touch the brake. Once you touch the brake, it will lock the torque converter and use the engine. I don't know how long the torque converter stays locked after you let off the brake. One of the techs over at http://flatratetech.com/6literpowers...ultimatebb.cgi is tracking that issue.
Old Jan 23, 2004 | 06:33 PM
SBV45's Avatar
SBV45
Part # 3C3Z-6750-AA That came off the bar code tag attached to the dipstick. Yes, I removed it before installing the dipstick.
ManfredVonRichtofen
WTB - Parts & other
Aug 13, 2016 03:33 PM
dcchadwick
Apr 25, 2016 07:53 AM
Chasm*18
Oct 23, 2015 07:39 PM
spikinfool05
Nov 10, 2012 03:35 PM
cocarvalho
May 27, 2011 02:57 PM
