Ive been runnind k-n for about a year, no apparant problems. It was much better than the stock one. My neighbor swears it doesn`t (k-n) allow enough air in though. My k-n just pops in stock box,not top of line setup. I`ll hookup tymar system in the future and see if theres a difference
I vote against the K&N filter. K&N's are known for thier abilty to coat Mass Airflow sensors with the filter oil. Scroll down to the gasser forums and you will see. The gassers are Naturally Aspirated (no turbo or super charger). Our diesel engines are turbo charged and move way more air than the gassers. This indicates to me that some of the filter oil could get sucked out and coat the turbine blades in the turbo, coat the intake air pipes, and coat the intercooler (if equipped) and reduce its efficiency. I think i'll stick with a dry filter.
Dry filters are great for city driving. But If your truck ever goes down a dusty road or visits a dusty construction site, or sees any sand then you need a oil type filter either the oil bath type or a oil impregnated. and the only way oil will go past the filter is if you don't follow the instructions on cleaning them. Thats why all OFF HWY racers use a K&N type filter.
Before we all get too crazy with the brand name battle, there has got to be something said for proper maintenance intervals. I mean leave any brand air filter on too long and you'll have problems. I too switched to a K&N with my stock airbox. I then started reading posts about "dusting" problems with the K&N as well as "oiling" issues. My stance is that if cleaned and oiled properly at the right intervals I haven't noticed either of these problems on my rig. I even checked and rechecked the air tube after the filter for any type of dusty build up or residue. I'm sure this doesn't sway the vote either way...just my two cents: -rip
