Batt. losing charge
Old Jan 20, 2004 | 09:53 PM
Hi_Tech_ Red_neck's Avatar
Hi_Tech_ Red_neck
Batt. losing charge
My 88 F150 4X4 (auto) keeps losing a charge.. I thought it might be the starter relay, but it still is draining from somewhere... Maybe the speed sensor?
If anyone could help me.. that would be awsome...
Thanks
Old Feb 27, 2004 | 11:25 AM
nfamous's Avatar
nfamous
go to auto zone or something, they will run a test on your battery and alternator for free... i think u have a bad battery
Old Feb 27, 2004 | 11:53 AM
kc73's Avatar
kc73
old trick: key off, disconnect neg bat cable, place test light between neg post and neg bat cable. if it lights you have a drain. pull fuses one at a time until test light does not come on or gets dimmer. that should narrow your search down to the faulty circuit. the dome light/underhood light will show up as a drain so take that into consideration during testing. good luck.
Old Feb 29, 2004 | 08:18 AM
howman442's Avatar
howman442
I agree with what kc73 said, it's the place to start. Don't forget to yank the light under the hood, if you have one it will cause a draw of about 1 amp when on. I have also heard of a defective hood lamp switch that keeps that light on even when the hood is closed. Good Luck!
warren561
Apr 2, 2013 04:31 PM
darren32
6.7L Power Stroke Diesel
39
Aug 16, 2012 03:48 PM
sparkkky
Mar 30, 2011 09:46 AM
300workhorse
Oct 6, 2009 05:06 PM
77_F150_4x4
Apr 4, 2000 11:34 PM
