Sponsored by: Auxito
98 4.6 egr problems
Old Jan 20, 2004 | 06:30 PM
m14dan's Avatar
m14dan
98 4.6 egr problems
I have been seeing this truck too much in my shop since we sold it. It's a 98 with a 6 code 4.6. It came in the day after it was sold with a check engine light for egr performance. Well I tested the egr and it was sticking a little so I replaced it. It came back a couple days ago with egr insufficient flow code. I tested the valve again and the sensor too and I could only get 1.5 volts max with on the sig wire with the egr wide open by a hand vaccume pump. It should have been 4-5 volts there. Anyway I thought easy enough just replace the sensor. I did and the code came back as I was backing out of the shop. I really started scratching my head then and thought maybe it was the flowmaster and duals not having enough backpressure to make the pfe sensor happy. I stopped up one pipe and same thing. Then I thought since it isn't on the downstream end it must be stopped up upstream. I pulled off the throttle body and adapter and sure enough the 2 egr ports in the adapter were plugged solid with hard oily carbon.
I cleaned it all out and problem solved.
I just thought I would share this experience incase anybody else is haveing a similar problem. I never in a million years would have thought to look there before trying everything else.
Old Jan 20, 2004 | 07:24 PM
bosshoss's Avatar
bosshoss
Hey m14dan.
That seems to be a problem on the mid to high mileage motors. That is the first thing i look for when i have a low flow problem. The next thing would be the DPFE sensor, have replaced quite a few of them. Congrats on the fix.
wiwillis1980
Mar 22, 2020 07:41 AM
Al_Cuevas
1997 - 2003 F150
93
Aug 13, 2016 08:50 AM
Richard.Parker
1997 - 2003 F150
Apr 2, 2013 08:14 PM
reamer
27
Nov 7, 2004 09:49 AM
pmurry
Oct 20, 2003 01:03 PM
