Sponsored by: Auxito
code po401 help
Old Apr 1, 2013 | 09:34 PM
Richard.Parker's Avatar
Richard.Parker
code po401 help
So I have a 1999 ford f 150 4x4 with the triton 4.6. I have worked around all day on this truck trying to fix different things on it. I am getting this code which is to little flow on the egr system. So I take the egr valve off and cleaned it and tested the diaphram inside and it moves freely with no problems. I reset the codes by taking the positive side off the battery and took it for a drive and after a few miles it came on again. So I got the same code again when checked and i bought a new dpfe sensor and changed it out. Drove it again after reseting codes and after a few miles it was right back on. I havent had it checked again to see if its the same code but im suspecting it is. I have not took the throttle body off and checked the egr ports to see if they are blocked. Is there anything else that c ould be causing it to read that same code over and over?
Old Apr 2, 2013 | 07:52 AM
Bluegrass 7's Avatar
Bluegrass 7
It's easy to tell if the passage is blocked by applying Vac to ther EGR while the motor is idleing.
If the motor begins to stumble the passage is open.
Good luck.
Old Apr 2, 2013 | 11:51 AM
Richard.Parker
Good luck.
I applied vac to the egr valve just like you said the engine stumbled. so i assume the egr ports are open. what else could cause it?
Old Apr 2, 2013 | 03:39 PM
Bluegrass 7
Only item left is the DPFE.
Good luck.
Old Apr 2, 2013 | 04:07 PM
Richard.Parker
Good luck.
I already put a new dpfe on it yesterday and unhooked battery to reset computer and when the light came on i had codes read again and it was showing the same code and also the codes for the abs and wheel sensors and i put new abs sensor in rearend and the abs light has not come back on. i sprayed starting fluid all over the motor and vacuum lines hoping to detect a leak but no luck. i even went ahead and took off throttle body today and cleaned the ports and i have reset computer again so i will see if it comes back on. if it does then im stuck other than maybe a vacuum solenoid.
Old Apr 2, 2013 | 04:55 PM
SteevenH's Avatar
SteevenH
DPFE Sensor probably. Check this web site out , it might help.
Part 1 -How to Test the Ford EGR Valve and DPFE Sensor.
Old Apr 2, 2013 | 08:14 PM
Richard.Parker
I may have found my problem. i had the hoses that go to the dpfe to the tube crossed. i hope thats it anyway plus i went ahead and got a new dpfe so i have my fingers crossed
Vegas F-150
1997 - 2003 F150
453
Jun 20, 2025 02:05 PM
davenpt
2004 - 2008 F150
21
Jul 7, 2014 01:33 PM
danboy282
Bronco II
Feb 10, 2012 12:16 AM
haul a55
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sep 11, 2006 04:49 PM
